Specification of package manifest format
Outline
This REP specifies a new package manifest format, initially released with Groovy Galapagos. It is only relevant for packages using the new catkin buildsystem. The new package.xml file replaces stack.xml and manifest.xml, used with the earlier rosbuild tools.
The decision to remove the concept of stacks, leaving only packages 1,2, drove the decision to merge the information contained in both stack.xml and manifest.xml.
The package.xml contains several kinds of information:
- descriptive data (i.e. a description, maintainer)
- dependencies on other ROS and system packages
- meta-information (i.e. the author and website)
- packaging information (i.e. the version)
A new filename replacing the existing ones
Instead of modifying the semantics and content of the old files a new filename is chosen to make it possible to distinguish old and new packages without parsing the contents of the xml file.
One file per package with all the information
Each package has one package.xml which contains all necessary data, instead of multiple separate files with semantically grouped information. Several tools, like the buildfarm and the wiki, need to use that information. They only need to fetch one file from each source package.
Store normalized data
All data are stored in atomic units for automated processing. For example, names and email addresses are stored separately.
Data format
Besides XML, which was used for stack.xml and manifest.xml, other formats were considered. YAML was investigated extensively during the Fuerte cycle, because it is easier for humans to read. Since benchmark results3 showed YAML parsing in Python to be ten times slower, the XML format remains.
Tags versus attributes
While plain text information can be stored in either attributes or tags the later is preferred for readability reasons.
Additional, mostly optional, information is stored in attributes of the related tag instead of grouping multiple tags inside a parent tag.
XML syntax restrictions
The allowed package.xml elements are tightly restricted. That way, tools can reliably detect errors and provide meaningful error messages should a user misspell any of the tags defined here.
Within the <export> element, tools may define additional tags, free from those restrictions.
If new top-level tags are needed, the format attribute of the <package> tag provides a migration path.
Package name restrictions
Package names are used in various contexts:
All ROS package names must be mapped to these conventions without generating collision. Therefore only lower case letters (a-z), numbers (0-9) and one delimiting character (_) can be used. The additional restriction that the first character be a letter is due to the requirements of some languages for naming packages or namespaces.
Data representation
The package manifest is an XML file, with restricted syntax.
The only top-level element allowed is <package>. Immediately subordinate to that are several required or optional elements, defined here. No other tags are permitted directly under the <package> element.
<package>
The <package> tag is the unique top-level tag in a package.xml file. All other tags are nested under it.
Attributes
format="NUMBER"(optional)Specifying the
package.xmlformat being used. If not set, the defaultformat="1"is assumed. That is the only format described here. If you are using a different format, please refer to the relevant specification. REP-01406 will describe format two.
Required Tags
The required tags in a package.xml file provide package meta-data:
Optional Tags
Meta-information
Optional, but recommended, meta-data include the names of the original authors and links to support documentation.
Dependencies
The dependencies and relations to other packages and system packages have been discussed in7 and are described using:
Various
There is a need for additional meta-data in the manifest for other tools that work with packages, like message generators and plugin discovery. All of this dynamic information is stored in tags under a single tag:
Tool providers are responsible for defining the tag structure their tool requires.
Example
<package>
<name>my_package</name>
<version>1.2.3</version>
<description>
ROS communications-related packages, including core client
libraries (roscpp, rospy, roslisp) and graph introspection tools
(rostopic, rosnode, rosservice, rosparam).
</description>
<maintainer email="someone@example.com">Someone</maintainer>
<license>BSD</license>
<license>LGPL</license>
<url type="website">http://wiki.ros.org/my_package</url>
<url type="bugtracker">http://www.github.com/my_org/my_package/issues</url>
<author>John Doe</author>
<author email="jane.doe@example.com">Jane Doe</author>
<buildtool_depend>catkin</buildtool_depend>
<build_depend version_gte="1.1" version_lt="2.0">genmsg</build_depend>
<build_depend>libgstreamer0.10-dev</build_depend>
<run_depend>libgstreamer0.10-0</run_depend>
<test_depend>gtest</test_depend>
<conflict>my_old_package</conflict>
<export>
</export>
</package>
<name>
The package name must start with a letter and contain only lowercase alphabetic, numeric or underscore characters8. The package name should be unique within the ROS community. It may differ from the folder name into which it is checked out, but that is not recommended.
The following recommended exemptions apply, which are optional for implementations:
- Dashes may be permitted in package names. This is to support maintaining a consistent dependency name when transitioning back and forth between a system dependency and in-workspace package, since many rosdep keys contain dashes (inherited from the Debian/Ubuntu name).
- In support of some legacy packages, capital letters may also be accepted in the package name, with a validation warning.
<version>
The version number of the package in the format MAJOR.MINOR.PATCH where each part is numeric only.
<description>
The description of the package. It can consist of multiple lines and may contain XHTML. But depending on where the description is used XML tags and multiple whitespaces might be stripped.
<maintainer> (multiple, but at least one)
The name of the person maintaining the package. All packages require a maintainer. For orphaned packages see below.
Attributes
email="name@domain.tld"(required)Email address of the maintainer.
An orphaned package is one with no current maintainer. Orphaned packages should use the following maintainer information to guide volunteers how they can claim maintainership:
Example
<maintainer email="ros-orphaned-packages@googlegroups.com">Unmaintained see http://wiki.ros.org/MaintenanceGuide#Claiming_Maintainership</maintainer>
<license> (multiple, but at least one)
Name of license for this package, e.g. BSD, GPL, LGPL. In order to assist machine readability, only include the license name in this tag. For multiple licenses multiple separate tags must be used. A package will have multiple licenses if different source files have different licenses. Every license occurring in the source files should have a corresponding <license> tag. For any explanatory text about licensing caveats, please use the <description> tag.
Most common open-source licenses are described on the OSI website.
Commonly used license strings:
- Apache 2.0
- BSD
- Boost Software License
- GPLv2
- GPLv3
- LGPLv2.1
- LGPLv3
- MIT
- Mozilla Public License Version 1.1
<url> (multiple)
A Uniform Resource Locator for the package's website, bug tracker or source repository.
It is a good idea to include <url> tags pointing users to these resources. The website is commonly a wiki page on ros.org where users can find and update information about the package.
Attributes
type="TYPE"(optional)The type should be one of the following identifiers:
website(default),bugtrackerorrepository.
<author> (multiple)
The name of a person who is an author of the package, as acknowledgement of their work and for questions.
Attributes
email="name@domain.tld"(optional)Email address of author.
<build_depend> (multiple)
Declares a rosdep key or ROS package name that this package requires at build-time.
The build and buildtool dependencies are used to determine the build order of multiple packages.
Attributes
All dependencies and relationships may restrict their applicability to particular versions. For each comparison operator an attribute can be used. Two of these attributes can be used together to describe a version range.
version_lt="VERSION"(optional)The dependency to the package is restricted to versions less than the stated version number.
version_lte="VERSION"(optional)The dependency to the package is restricted to versions less or equal than the stated version number.
version_eq="VERSION"(optional)The dependency to the package is restricted to a version equal than the stated version number.
version_gte="VERSION"(optional)The dependency to the package is restricted to versions greater or equal than the stated version number.
version_gt="VERSION"(optional)The dependency to the package is restricted to versions greater than the stated version number.
<buildtool_depend> (multiple)
Declares a rosdep key or ROS package name for a tool that is executed during the build process. For cross-compilation, one must distinguish these from normal build dependencies, which may be linked with your package and must be compiled for the target architecture, not the build system.
Attributes
The same attributes as for <build_depend> (multiple).
<run_depend> (multiple)
Declares a rosdep key or ROS package name that this package needs either at run-time or as part of some exported build interface.
The <run_depend> declares two different types of package dependencies. One is for shared libraries, executables, Python modules, launch scripts and other files required for running your package.
The second type of <run_depend> is for transitive build dependencies. A common example is when one of your dependencies provides a header file included in some header exported by your package. Even if your package does not use that header when building itself, other packages depending on your header will require those transitive dependencies when they are built.
Attributes
<test_depend> (multiple)
Declares a rosdep key or ROS package name that your package needs for running its unit tests.
A <test_depend> may not reference any package also declared using a <build_depend>, <buildtool_depend> or <run_depend>.
Attributes
<conflict> (multiple)
Declares a rosdep key or ROS package name with which your package conflicts. This package and the conflicting package cannot be installed at the same time. This maps to conflicts for both dpkg and rpms.
For a detailed explanation how these relationships are used see 9 and10.
Attributes
<replace> (multiple)
Declares a rosdep key or ROS package name that your package replaces. This maps to Replaces for dpkg and Obsoletes for rpms.
Attributes
<export>
This tag serves as a container for additional information various packages and subsystems need to embed. To avoid potential collisions packages must use their package name as their tag name inside the export block. The content of that tag is up to the package to define and use.
Existing rosbuild export tags for tools using pluginlib remain unchanged. For example, a package which implements an rviz plugin might include this:
<export>
<rviz plugin="${prefix}/plugin_description.xml"/>
</export>
The following are some tags used within an <export> for various package and message generation tasks.
<architecture_independent/>
This empty tag indicates that your package contains no architecture-specific files.
<build_type>
This tag indicates the package's build type. If unspecified, the default is catkin. Typical value is cmake to denote a plain CMake package, but any string is allowed.
The <build_type> tag may only be specified once.
<deprecated>
This tag indicates that your package is deprecated, enabling tools to notify users about that fact. The tag may be empty or may optionally contain an arbitrary text providing user more information about the deprecation:
<export>
<deprecated>
This package will be removed in ROS Hydro. Instead, use package
FOO, which provides similar features with a different API.
</deprecated>
</export>
<message_generator>
The content defines the identifier for the language bindings generated by this package, i.e. in gencpp this is set to cpp:
<export>
<message_generator>cpp</message_generator>
</export>
<metapackage/>
This empty tag declares a special kind of catkin package used for grouping other packages. Users who install the Debian or RPM package for a catkin metapackage will also get all the packages directly or indirectly included in its group. Metapackages may not install any code or other files, although package.xml does get installed automatically. They can depend on other metapackages, if desired, but regular catkin packages cannot.
Metapackages can be used to resolve dependencies declared by legacy rosbuild stacks not yet converted to catkin. Catkin packages must depend directly on the packages they use, not on any metapackages.
A good use for metapackages is to group the major components of your robot and then provide a comprehensive grouping for your whole system.
Every metapackage must have a CMakeLists.txt containing these commands:
cmake_minimum_required(VERSION 2.8.3)
project(PACKAGE_NAME)
find_package(catkin REQUIRED)
catkin_metapackage()
Because the metapackage CMakeLists.txt contains a catkin macro, its package.xml must declare a buildtool dependency on catkin:
Additional buildtool, build or test dependencies are not permitted.
Metapackages list all packages or other metapackages in their group using <run_depend> tags:
<run_depend>your_custom_msgs</run_depend>
<run_depend>your_server_node</run_depend>
<run_depend>your_utils</run_depend>
Compatibility
Modification to previous specifications
- Authors are now split into authors and maintainers.
- Multiple people and their emails are specified in separate tags and attributes.
- Authors are now optional.
- Maintainers must provide an email address.
- At least one maintainer is now required.
- Multiple licenses can now be used, even though a single license per package is desired.
- Multiple
urltags can be specified withtypeattributes indicating their meanings.- The former
dependandrosdephave been unified, but also split into various types of dependencies.- The
exporttag:
- The
cpptag has been dropped, it is handled by catkin.- The
roslangtag has been dropped, it is handled by catkin.
- The
copyrighttag has been dropped.- The
logotag has been dropped.- The
reviewtag has been dropped, that information will be stored on the website of that package.- The
versioncontroltag has been dropped.
Backward compatibility
All tools using stack.xml and manifest.xml are updated to work with package.xml files.
Migration to the new format only affects packages being converted to catkin. Existing rosbuild packages remain the same. Rosdep distinguishes between catkin and rosbuild and returns the correct system dependencies.
Affected tools
List of tools affected by the specification (which is very like not complete):
- bloom
- buildfarm
- catkin
- roscd
- rosdep
- rosdoc
- roslaunch
- roslib
- rospack
- rospkg
- rosrun
- rosstack
Several tools are affected by the transition from packaging packages instead of stacks and not really by the specification of the format for the package information.
Future enhancements
Additional meta-information can be added within the export tag, as needed.
New features related to the infrastructure can be specified and integrated using additional tags and attributes, but this requires introducing a new <package> format number.
Schema
A schema defining the structure specified in this document is available at11. To specify the schema within a manifest you can reference a self contained schema file like this:
<?xml version="1.0"?> <?xml-model href="http://download.ros.org/schema/package_format1.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?> <package>
Buildsystem mailing list discussion: "Request for comment REP 127" ↩︎
Buildsystem mailing list discussion: "Dependency tag types for REP 127" ↩︎
Comparison between YAML and XML for manifests (https://github.com/ros/catkin/issues/128) ↩︎
Declaring relationships between packages (Debian Policy Manual) (http://www.debian.org/doc/debian-policy/ch-relationships.html) ↩︎
Advances RPM Packaging (Fedora Documentation) (http://docs.fedoraproject.org/en-US/Fedora_Draft_Documentation/0.1/html/RPM_Guide/ch-advanced-packaging.html) ↩︎
REP-0140 (https://ros.org/reps/rep-0140.html) ↩︎
Naming conventions (http://www.ros.org/wiki/ROS/Patterns/Conventions#Naming_ROS_Resources) ↩︎
Schema file (https://github.com/ros-infrastructure/rep/blob/master/xsd/package_format1.xsd) ↩︎
