A Standard interface for Aerial Vehicles
This REP is written to provide a common interface for aerial vehicles. This interface is designed to promote interoperability and reusability of core functionality between diverse aerial vehicles. By leveraging the interfaces defined in this REP we both tools and libraries can be designed to be reusable between different frameworks and vehicles. It is expected that aerial vehicles can and will implement additional interfaces in addition to these core interfaces. When choosing an interface these should be considered the default and only change away from them for a good reason.
These interfaces are designed to be relevant for all types of aerial vehicles whether multi-copter, fixed-wing, hybrid, transitional or other. Like ground robots, the core abstraction is the same for all vehicles regardless of their method of motivation.
There are a lot of developers around the world using ROS on aerial vehicles. As such there are also many different implementations which are similiar but not exactly compatible. A short list of existing known bridges and implementations follows:
  • astec_mav_framework1
  • autopilot_bridge2
  • CRATES3
  • dji_sdk_dji2ros4
  • dji_sdk5
  • hector_quadrotor6
  • mav_tools7
  • mavlink2ros8
  • mavros9
  • roscopter10
  • rospilot11
Due to a lack of common interfaces the majority of the above packages cannot be used together. By implementing common interfaces elements of each package can be used in conjunction with elements of a different package. This will allow much better collaboration between projects and allow a reduction in duplicate efforts to implement the same functionality.
There are also a lot of interfaces already well developed from other domains which can be brought into the aerial vehicle domain. This REP seeks to also integrate as many of those reusable interfaces as well to provide the greatest compatibilty with those other domains.
Other interface definitions
There are a lot of messages already defined. These messages definitions were used to help define this set.
  • DroneKit12
  • mav_msgs13
  • mavlink14
  • mavlink215
  • mavros_msgs16
  • nav_msgs17
  • trajectory_msgs18
Reference Abstractions
For this document we will use the following abstractions of the architecture. These abstractions are used to define the interfaces, however it is not required that a given system implement all the interfaces. A given system may implement subsets of these interfaces.
Control Abstractions
For controlling an aerial vehicle we will use the following terms for the interfaces.
graph LR
  na[ ]
  tc[Trajectory Controller]
  ac[Attitude Controller]
  rc[Rate Controller]
  va[Vehicle Abstraction]
  na ==>|Trajectory|tc
  tc ==>|Pose|ac
  ac ==>|Rate|rc
  rc ==>|Acceleration|va
  va -.-> am[Allocation Matrix]
  va -.-> mixer
  am -.-> Actuators
  mixer -.-> Actuators
High Level Architecture
A higher level view of the system uses the following abstraction.
graph LR
  GCS[Ground Control Station]
  CS[Collision Sensors]
  OS[Odometry Sensors]
  C[Controller]
  L[ ]
  style L fill:#fff,stroke:#ff0,stroke-width:0px;
  L --> CS
  L --> GCS
  L --> OS
  subgraph Generic Planning Framework
  CM[Collision Mapping]
  MSC[Planner e.g.<br>Minimum Snap Trajectory Generator]
  CM ---|Shared State|MSC
  end
  CS -->|Obstacle Observations|CM
  OS -->|Odometry|MSC
  OS -->|Odometry|CM
  OS -->|Odometry|C
  GCS -->|Goals|MSC
  MSC -->|Control Abstraction|C
  %% Links to L
  linkStyle 0 fill:#fff,stroke:#ff0,stroke-width:0px;
  linkStyle 1 fill:#fff,stroke:#ff0,stroke-width:0px;
  linkStyle 2 fill:#fff,stroke:#ff0,stroke-width:0px;
Coordinate Frames
It is expected that users of this interface will also follow the coordinate frame conventions layed out in REP 10519.
Proposed Interfaces
Control Interfaces
Trajectory Control Interface
For sending trajectories in 3D space there already exists a message used for free space planning. This message used is trajectory_msgs/MultiDOFJointTrajectory20 and is actively used by planning frameworks already.
This message is not the most straight forward to parse as it has a lot of optional fields which increases the complexity and requires consistent labeling and filling. The complexity of the message parsing is traded off against supporting a relatively compact representations.
  • Datatype: trajectory_msgs/MultiDOFJointTrajectory21
  • Topic: command_trajectory
# The header is used to specify the coordinate frame and the reference time for the trajectory durations
Header header
# A representation of a multi-dof joint trajectory (each point is a transformation)
# Each point along the trajectory will include an array of positions/velocities/accelerations
# that has the same length as the array of joint names, and has the same order of joints as
# the joint names array.
string[] joint_names
MultiDOFJointTrajectoryPoint[] points
Pose Interface
The message to send a goal pose is geometry_msgs/PoseStamped22. This is a very highly used standard message and contains precisely the information needed.
  • Datatype: geometry_msgs/PoseStamped23
  • Topic: command_pose
# A Pose with reference coordinate frame and timestamp
Header header
Pose pose
The reference position is the origin of the base_link as defined in#REP105
Rate Interface
The message to send a velocity command is geometry_msgs/TwistStamped24. This is the standard way to command ROS vehicles. The datatype is not intended to be used in an open loop control system.
  • Datatype: geometry_msgs/TwistStamped25
  • Topic: command_velocity
std_msgs/Header header
  uint32 seq
  time stamp
  string frame_id
geometry_msgs/Twist twist
  geometry_msgs/Vector3 linear
    float64 x
    float64 y
    float64 z
  geometry_msgs/Vector3 angular
    float64 x
    float64 y
    float64 z
The command is a body relative set of velocities in linear and angular space. This diverges from the common geometry_msgs/Twist26 used by some ground robots. A pure Twist based interface could be provided for backwards compatibility as well. It was chosen to diverge here since this is a much more powerful inteface for the vehicles and does not require all commands to be reverse calculated for the instantaneous attitude of the vehicle. Furthermore, the timestamp field allows for improved timeout behavior due to stale command data.
This is replacing mav_msgs/AttitudeThrust27 and mav_msgs/RollPitchYawrateThrust28.
Acceleration Interface
The message to send a velocity command is geometry_msgs/TwistStamped29. The datatype is not intended to be used in an open loop control system.
  • Datatype: geometry_msgs/TwistStamped30
  • Topic: command_acceleration
  uint32 seq
  time stamp
  string frame_id
    float64 x
    float64 y
    float64 z
    float64 x
    float64 y
    float64 z
The command is a body relative set of accelerations in linear and angular space. The reference position is the origin of the base_link as defined in#REP105
This is replacing the mav_msgs/RateThrust31 message for a more standard one with the specific call out of the base_link.
High Level Interfaces
Odometry Interface
To communicate odometry information the nav_msgs/Odometry message will be used.32 This is the standard message used throughout ROS systems already, many modules already take advantage of it. However there are many use cases for aerial vehicles when the estimation of the acceleration is important. So an additional message will be defined which provides acceleration in addition to position and velocity already defined. This additional message will be published in parallel. For backwards compatibility all systems should publish both.
  • Datatype: nav_msgs/Odometry33
  • Topic: odom
# This represents an estimate of a position and velocity in free space.
# The pose in this message should be specified in the coordinate frame given by header.frame_id.
# The twist in this message should be specified in the coordinate frame given by the child_frame_id
string child_frame_id
geometry_msgs/PoseWithCovariance pose
geometry_msgs/TwistWithCovariance twist
  • Datatype: nav_msgs/OdometryWithAcceleration [proposed]
  • Topic: odometry
# This represents an estimate of a position, velocity, and acceleration in free space.
# The twist and acceleration in this message should be specified in the coordinate frame given by the child_frame_id
geometry_msgs/TwistWithCovariance acceleration
Goal Interface
It is expected that there will be several high level ways to communicate goals which are application specific. A standard way to communicate goals will also be important following the mavlink protocol we can send the same messages over ROS using the following pair of messages.
  • SubDatatype: nav_msgs/GlobalPosition [proposed]
  • Topic: command_gps_pose
uint8 coordinate_frame
uint8 FRAME_GLOBAL_INT = 5
uint8 FRAME_GLOBAL_REL_ALT = 6
uint8 FRAME_GLOBAL_TERRAIN_ALT = 11
uint16 type_mask
uint16 IGNORE_LATITUDE = 1    # Position ignore flags
uint16 IGNORE_LONGITUDE = 2
uint16 IGNORE_ALTITUDE = 4
uint16 IGNORE_VX = 8  # Velocity vector ignore flags
uint16 IGNORE_VY = 16
uint16 IGNORE_VZ = 32
uint16 IGNORE_AFX = 64    # Acceleration/Force vector ignore flags
uint16 IGNORE_AFY = 128
uint16 IGNORE_AFZ = 256
uint16 FORCE = 512    # Force in af vector flag
uint16 IGNORE_YAW = 1024
uint16 IGNORE_YAW_RATE = 2048
float64 latitude
float64 longitude
float32 altitude  # in meters, AMSL or above terrain depending on coordinate_frame value
geometry_msgs/Twist velocity
geometry_msgs/Twist acceleration_or_force
float32 yaw
To send a series of goals a list of GlobalPositions can be used.
  • Datatype: nav_msgs/GlobalWaypoints [proposed]
nav_msgs/GlobalPosition[] waypoints
Currently Unspecified
The obstacle observations are expected to use common sensor messages. However since there are a large variety of potential sensors, this interface will not be defined in this REP. It is recommended to use the common messages such as LaserScan, DepthImage, and PointCloud2 from sensor_msgs whenever possible.34
Shared State
The shared state between the collision mapping and motion planning controller is expected to be very specific to the implementation. As such it is not proposed to be standardized.
Missions
Currently there are quite a few varieties of missions data formats that are available. The most prominent is the mavlink mission protocol.35 These missions are heavily used and often customized. A ROS equivalent could be defined but the current mission protocol is both relatively complicated and only provides relatively simple primitive constructs with which to compose a mission. It is expected that mission planners can dynamically construct lower level controls for the vehicle that can then be executed upon by the vehicle controller. The simplest of these mission planners would generate a target waypoint for the vehicle to fly to and send a new one when there's a new position to fly to. A slightly more complex flight mission might send a series of waypoints which the vehicle will follow until the end. If a change in path is required the mission planner will deliver a whole new set of waypoints for the vehicle to follow. For more complicated missions the mission planner can generate the lower level trajectories for controlling the vehicles path more specifically, such as when doing an orbit or other more advanced mission operation. There are a lot more advanced missions that can be run with state machines and higher level logic. Until there is more development in this area we will not propose a standardized mission profile.
Other Interfaces
Battery State
Aerial vehicles should use the sensor_msgs/BatteryState message for reporting their battery status.36 This is a recently standardized message which is much more broadly applicable than aerial vehicles and has already been standardized.
  • Datatype: sensor_msgs/BatteryState37
  • Topic: battery_state
Vehicle Status
Drones could have different configurations or types as well as define failsafes, engine failures or hardware in the loop setup. These are the fields proposed for this message
  • Datatype: proposed_aerial_msgs/VehicleStatus (proposed)
  • Service Name: status
uint8 HIL_STATE_OFF = 0
uint8 HIL_STATE_ON = 1
uint8 VEHICLE_TYPE_UNKNOWN = 0
uint8 VEHICLE_TYPE_ROTARY_WING = 1
uint8 VEHICLE_TYPE_FIXED_WING = 2
uint8 VEHICLE_TYPE_ROVER = 3
uint8 VEHICLE_TYPE_VTOL = 4
uint8 system_type     # system type
bool engine_failure   # Set to true if an engine failure is detected
bool failsafe         # true if system is in failsafe state
uint8 hil_state       # current hil state
Flight Modes
Drones have quite a few flight modes. For example the PX4 Flight Modes number between 9 and 12 for different configurations.38 Many of these different modes are modifying which user inputs are used and/or how they are interpreted. For working with ROS it is expected that the user inputs will be modulated and received through the ROS system and that the system will be in control the whole time including implementing fallback and recovery behaviors. Without the need for these extra modes we will reduce the state diagram significantly. The autopilot itself is expected to be in Offboard control mode for most configurations using ROS. In theory all of the states could be eliminated and the arming, takeoff, landing, and return to land logic could be fully implemented, but we will keep those states which are related to safety system already implemented.
To that end the following modes for ROS flight operations are proposed.
graph LR
  DISARMED[Disarmed]
  ARMED[Armed]
  FLYING[Flying]
  LANDED[Landed]
  RTL[Return to Land]
  DISARMED --> |Arm| ARMED
  ARMED --> |Takeoff| FLYING
  FLYING --> |Land| LANDED
  FLYING --> | RTL<br>Lost Link | RTL
  LANDED --> |Auto Disarm| DISARMED
  RTL --> |Disarm| DISARMED
  FLYING --> |Disarm| DISARMED
  RTL --> | Auto Land | LANDED
  %% Links to DISARMED
  linkStyle 5 fill:#fff,stroke:#f00,stroke-width:3px;
  linkStyle 6 fill:#fff,stroke:#f00,stroke-width:3px;
Note that the red disarm transitions are potentially unsafe as they could lead to the vehicle falling.
  • Datatype: mav_msgs/FlightMode (proposed)
uint8 FLIGHT_MODE_DISARMED=0
uint8 FLIGHT_MODE_ARMED=1
uint8 FLIGHT_MODE_FLYING=2
uint8 FLIGHT_MODE_LANDED=3
uint8 FLIGHT_MODE_RTL=4
uint8 flight_mode # The flight mode indicated
  • Datatype: mav_msgs/SetFlightMode (proposed)
  • Service Name: set_flight_mode
mav_msgs/FlightMode goal # The desired flight mode
mav_msgs/FlightMode result # The resultant state after the attempted transition.
bool success # True if desired change was executed False otherwise.
One of the most common protocols for drones is Mavlink.39
It is important that we define the minimal set which provides coverage of general flying vehicles. This type of abstraction allows the greatest level of reusability of components between different systems. The goal of a standard message set is to define the things that are completely general, and let implementers define their own specializations for their specific systems.
As those specifications become more mature they can also be standardized as optional extensions to the defined interface. When using ROS messages these extensions will be discoverable and shareable to facilitate converging implementations.
This section will provide a guide of suggested mappings of existing Mavlink messages to existing ROS messages outside the above minimal specification. This will be useful for users who are familiar with Mavlink or using a system with mavlink and need to bridge between systems.
This is a departure from Mavlink where things needed to be fully defined in the spec or at least allocated out with negotiated message IDs so that messages didn’t collide. Also the availability of topics allows the use of the same data structures for different purposes. For example there doesn’t need to be three IMU messages to tell the different IMUs apart.
This list has focused on getting coverage of40 it has been grouped into basic categories.
Text Status Outputs
Code should use the ROS_CONSOLE or RCL status api to report status. This has infrastructure for enabling and setting verbosity levels at startup and runtime as well as changing them during runtime and has standard messages for remotely monitoring and controlling them.
  • STATUSTEXT
ROS Messages in REP 147
For quick reference the following mavlink messages are considered covered in the specification above.
Position reporting
There are many position reporting methods defined in Mavlink. They are all variations on PoseWithCovarianceStamped with different relevant frame_ids.
  • LOCAL_POSITION_NED_SYSTEM_GLOBAL_O
  • LOCAL_POSITION_NED_COV
  • GLOBAL_POSITION_INT_COV
  • ATTITUDE_QUATERNION_COV
  • ALTITUDE
Battery Status
Defined above.
  • BATTERY_STATUS
Position commands
These are all covered in the hierarchy of commands in REP 147
  • POSITION_TARGET_GLOBAL_INT
  • SET_POSITION_TARGET_GLOBAL_INT
  • POSITION_TARGET_LOCAL_NED
  • SET_POSITION_TARGET_LOCAL_NED
  • ATTITUDE_TARGET
  • SET_ATTITUDE_TARGET
  • MANUAL_SETPOINT
Generic Command
These should be behaviors that then output via the REP’s hierarchy of command topics. Each node can have logic or parameters to react according to a behavior. It’s no longer a global state of the system.
  • COMMAND_ACK
  • COMMAND_LONG
  • COMMAND_INT
Generic Sensor Info
There are a lot of existing ROS messages in the sensor_msgs package41 that can be immediately reused in drones. A few examples are as follows.
  • DISTANCE_SENSOR -- sensor_msgs/Range42
  • CAMERA_TRIGGER -- std_srvs/Trigger43
  • OPTICAL_FLOW_RAD -- These could use a new message but I’d want it to be driven by an active user/developer. There might also be potential in existing vision_msgs TODO(tfoote)
  • VISION_SPEED_ESTIMATE -- geometry_msgs/TwistWithCovarianceStamped on a specific topic.
  • VISION_POSITION_ESTIMATE and GLOBAL_VISION_POSITION_ESTIMATE -- geometry_msgs/PoseWithCovarianceStamped on a specific topic TODO(tfoote) link
Image Transport
For transporting images and image streams it is recommended to use the [image_transport system](http://wiki.ros.org/image_transport) from ROS. It is capable of streaming raw as well as compressed image streams and selecting the mode at runtime. There is a plugin system to add support for different compressions and transports.
This would cover:
  • ENCAPSULATED_DATA
  • DATA_TRANSMISSION_HANDSHAKE
Wind Information
WIND_COV is recommended to be represented by a geometry_msgs/TwistWithCovarianceStamped on a specific topic.
Candidates for Future Porting
Barometer
The absolute measurements can be captured by sensor_msgs/FluidPressure TODO LINK TODO A barometer message with the relative measurements would be a good extension.
Related mesages are:
  • RAW_PRESSURE
  • SCALED_PRESSURE
  • SCALED_PRESSURE2
  • SCALED_PRESSURE3
Custom High Level Summary
The message HIGH_LATENCY is a custom summary message for sending the state out. It’s optimized for a specific use case with specific hardware. It can easily be directly ported, but is is recommended be broken down into a few different messages or composed of a few different messages forwarded over the high latency/low bandwidth link instead of defining a new datatype.
Vibration Levels
This is uncaptured but is not documented well enough to define a message and is not a primary flight concern but more of a diagnostic.
  • VIBRATION
GPS Messsages
For GPS messages there already exists a [NavSatFix](http://docs.ros.org/api/sensor_msgs/html/msg/NavSatFix.html) and a [NavSatStatus](http://docs.ros.org/melodic/api/sensor_msgs/html/msg/NavSatStatus.html) which are recommended for general GPS position information and status.
  • GPS_STATUS
There are also a bunch of raw and other specific data types that are potentially useful in Mavlink, but are moderately specific to the localization hardware. As such they would be better ported for specific hardware support packages and not considered fully standardized.
  • GPS_INPUT
  • GPS_RTCM_DATA
  • GPS2_RTK
  • GPS_RTK
  • GPS2_RAW
  • GPS_INJECT_DATA
  • GPS_GLOBAL_ORIGIN
  • SET_GPS_GLOBAL_ORIGIN
  • GPS_RAW_INT
IMU Messages
There are existing IMU messages that should be reused instead of defining new ones. http://docs.ros.org/melodic/api/sensor_msgs/html/msg/Imu.html There’s already a [proposal upstream](https://github.com/ros/common_msgs/pull/101) for improvements that we will plan to integrate with upper triangular covariance used in the PX4 stack.
  • RAW_IMU
  • HIGHRES_IMU
  • SCALED_IMU
  • SCALED_IMU2
  • SCALED_IMU3
Custom Waypoint Logic
This is mostly encoding specific messages related to autopilot implementation behaviors. It is recommended to be captured by a generic waypoint communicated on a specific topic or service instead of as a dedicated message.
  • SET_HOME_POSITION
  • HOME_POSITION
  • LANDING_TARGET
  • FOLLOW_TARGET
Parameters
These messages can be replaced by using parameters on the nodes to set these values.
  • MESSAGE_INTERVAL
  • SERIAL_CONTROL
ROS provides parameters set and get services which can replace the below messages.
  • PARAM_SET
  • PARAM_VALUE
  • PARAM_REQUEST_LIST
  • PARAM_REQUEST_READ
Data Logging
Logging and playback are recommended to be managed by rosbag. There are APIs already implemented for controlling recording remotely. There are not currently apis for downloading the data but that is likely better done using a standard file transfer mechanism than through a runtime behavior.
Related mavlink messages include:
  • LOG_REQUEST_END
  • LOG_ERASE
  • LOG_DATA
  • LOG_REQUEST_DATA
  • LOG_ENTRY
  • LOG_REQUEST_LIST
  • FILE_TRANSFER_PROTOCOL
Time
It is recommended to use the standard ROS time abstraction.
  • SYSTEM_TIME
Connectivity Checks
There are many capabilities of DDS to check for liveliness and heartbeats built into the communication layer that can be leveraged. Also the bond libraries from ROS1 have heartbeat logic.
  • PING
  • HEARTBEAT
It is recommended that acknowledgment of message receipt be embedded into the communication layer using the reliable transport and callbacks if the message does not arrive.
  • COMMAND_ACK
Security
ROS2 using DDS's security extensions can provide cryptographically secure fine grained authentication, access control, and encryption. It is recommended to use that toolchain for security.
  • AUTH_KEY
  • CHANGE_OPERATOR_CONTROL
  • CHANGE_OPERATOR_CONTROL_ACK
Skipped in the analysis
  • RESOURCE_REQUEST not flight related
  • V2_EXTENSION not clearly documented
Debugging Outputs
These are generic data types that are defined to let the developer send basically anything over the network. Instead of shoehorning data into these few generic datatypes on a ROS based system, it is recommended that the developer define their own debug messages and send them along capturing exactly what they want with the appropriate datatypes or structures.
  • DEBUG
  • NAMED_VALUE_INT
  • NAMED_VALUE_FLOAT
  • DEBUG_VECT
  • MEMORY_VECT
Messages that are not generic
HITL Specific Messages
These are simulation specific messages that are specific to integrating the autopilot with simulation. The current messages are also specific to the autopilot implementation and not generic enough to necessarily use alternative autopilots.
  • HIL_STATE_QUATERNION
  • HIL_OPTICAL_FLOW
  • HIL_GPS
  • HIL_SENSOR
  • SIM_STATE
  • HIL_ACTUATOR_CONTROLS
  • HIL_RC_INPUTS_RAW
  • HIL_CONTROLS
Hardware Specific Info
These mavlink messages are coupled directly to hardware and are not abstracted at an optimal level to be considered universal for all vehicles.
  • POWER_STATUS
  • TIMESYNC
  • RADIO_STATUS
Mocap Specific
These mocap systems can use generic position reports with covariance on a specific topic instead of needing a custom datatype.
  • ATT_POSE_MOCAP
  • VICON_POSITION_ESTIMATE
Low Level Control
This is too low level for a good abstraction, it’s not valid on all types of hardware.
  • SET_ACTUATOR_CONTROL_TARGET
  • ACTUATOR_CONTROL_TARGET
  • MANUAL_CONTROL
  • RC_CHANNELS_OVERRIDE Also overriding user commands
  • RC_CHANNELS
  • PARAM_MAP_RC
Low Level Feedback
  • SERVO_OUTPUT_RAW
  • RC_CHANNELS_RAW
  • RC_CHANNELS_SCALED
Autopilot Version information
This can be captured as a parameter.
  • AUTOPILOT_VERSION
Display specific message
This is a specific message for displaying into a HUD, it’s aggregating and duplicating existing data that doesn’t need to be generally broadcast separately.
  • VFR_HUD
Component specific debug Messages
This is a debug/status message that’s specific to the current estimator design. The parameters are not right for a particle filter based estimator or another style of implementation.
  • ESTIMATOR_STATUS
These are messages that can share the state of controllers but is only valid for specific controllers and thus not a good candidate for standardization.
  • CONTROL_SYSTEM_STATE
  • NAV_CONTROLLER_OUTPUT
Mission Management
The current mission definitions are a basic set of primitive behaviors. They are a significant subset of the capabilities of vehicles and those primitives should not be built into a next generation abstraction for drones. However that’s not to say that the mission concept should be eliminated. Going forward the current mission structure is easy for operators to think about and that should be retained, but instead of considering the missions a standard interface for the drones. They should be parsed and simply generate the REP 147 compliant trajectory that the drone can follow. In the future this will allow the implementation to extend the mission waypoints types and add more complex logic into the missions and remain compatible with all drones.
  • MISSION_ITEM_INT
  • MISSION_REQUEST_INT
  • MISSION_ACK
  • MISSION_ITEM_REACHED
  • MISSION_CLEAR_ALL
  • MISSION_COUNT
  • MISSION_REQUEST_LIST
  • MISSION_CURRENT
  • MISSION_SET_CURRENT
  • MISSION_REQUEST
  • MISSION_ITEM
  • MISSION_WRITE_PARTIAL_LIST
  • MISSION_REQUEST_PARTIAL_LIST
VTOL Specific State
This is a very hardware specific message that was added for a specific hardware type. This is a good example of an extension that was required because the standard was not abstract enough.
  • EXTENDED_SYS_STATE
Collision Information
These collision messages are customized to a specific implementation and do no generalize.
  • COLLISION
  • ADSB_VEHICLE
  • TERRAIN_DATA
  • TERRAIN_CHECK
  • TERRAIN_REPORT
  • SAFETY_ALLOWED_AREA
  • SAFETY_SET_ALLOWED_AREA
Summary
Existing interfaces
  • Battery State via sensor_msgs/BatteryState44
  • Trajectory via trajectory_msgs/MultiDOFJointTrajectory45
  • Rates via mav_msgs/RollPitchYawrateThrust46 or mav_msgs/AttitudeThrust47
  • Accelerations via mav_msgs/RateThrust48
  • Obstacle information from common sensor_msgs49
  • Odometry vianav_msgs/Odometry50
Proposed New Interfaces
  • Extended Odometry via proposed nav_msgs/OdometryWithAcceleration [propoised]
  1. astec_mav_framework (http://wiki.ros.org/asctec_mav_framework↩︎
  2. autopilot_bridge (https://github.com/mikeclement/autopilot_bridge↩︎
  3. CRATES (https://bitbucket.org/asymingt/crates↩︎
  4. dji_sdk_dji2ros (http://www.ros.org/browse/details.php?distro=indigo&name=dji_sdk_dji2mav↩︎
  5. dji_sdk (http://wiki.ros.org/dji_sdk↩︎
  6. hector_quadrotor (http://wiki.ros.org/hector_quadrotor↩︎
  7. mav_tools (http://wiki.ros.org/mav_tools↩︎
  8. mavlink2ros (https://github.com/posilva/mav2rosgenerator↩︎
  9. mavros (http://wiki.ros.org/mavros↩︎
  10. roscopter (https://code.google.com/p/roscopter/↩︎
  11. rospilot (http://wiki.ros.org/rospilot↩︎
  12. DroneKit (http://dronekit.io/↩︎
  13. mav_msgs (http://wiki.ros.org/mav_msgs↩︎
  14. Mavlink (https://mavlink.io/en/↩︎
  15. Mavlink2 (https://github.com/diydrones/mavlink/blob/mavlink2-wip/doc/MAVLink2.md↩︎
  16. mavros (http://wiki.ros.org/mavros↩︎
  17. nav_msgs (http://wiki.ros.org/nav_msgs↩︎
  18. trajectory_msgs (http://wiki.ros.org/trajectory_msgs↩︎
  19. REP 105: Coordinate Frames for Mobile Platforms (http://www.ros.org/reps/rep-0105.html↩︎
  20. (http://docs.ros.org/api/trajectory_msgs/html/msg/MultiDOFJointTrajectory.html↩︎
  21. (http://docs.ros.org/api/trajectory_msgs/html/msg/MultiDOFJointTrajectory.html↩︎
  22. (http://docs.ros.org/api/geometry_msgs/html/msg/PoseStamped.html↩︎
  23. (http://docs.ros.org/api/geometry_msgs/html/msg/PoseStamped.html↩︎
  24. geometry_msgs/TwistStamped (http://docs.ros.org/api/geometry_msgs/html/msg/TwistStamped.html↩︎
  25. geometry_msgs/TwistStamped (http://docs.ros.org/api/geometry_msgs/html/msg/TwistStamped.html↩︎
  26. geometry_msgs/Twist (http://docs.ros.org/api/geometry_msgs/html/msg/Twist.html↩︎
  27. mav_msgs/AttitudeThrust (http://docs.ros.org/jade/api/mav_msgs/html/msg/AttitudeThrust.html↩︎
  28. mav_msgs/RollPitchYawrateThrust (http://docs.ros.org/indigo/api/mav_msgs/html/msg/RollPitchYawrateThrust.html↩︎
  29. geometry_msgs/TwistStamped (http://docs.ros.org/api/geometry_msgs/html/msg/TwistStamped.html↩︎
  30. geometry_msgs/TwistStamped (http://docs.ros.org/api/geometry_msgs/html/msg/TwistStamped.html↩︎
  31. mav_msgs/RateThrust (http://docs.ros.org/jade/api/mav_msgs/html/msg/RateThrust.html↩︎
  32. odometry (http://www.ros.org/doc/api/nav_msgs/html/msg/Odometry.html↩︎
  33. odometry (http://www.ros.org/doc/api/nav_msgs/html/msg/Odometry.html↩︎
  34. (http://wiki.ros.org/sensor_msgs↩︎
  35. Mavlink Mission protocol (https://mavlink.io/en/services/mission.html↩︎
  36. sensor_msgs/BatteryState (http://docs.ros.org/api/sensor_msgs/html/msg/BatteryState.html↩︎
  37. sensor_msgs/BatteryState (http://docs.ros.org/api/sensor_msgs/html/msg/BatteryState.html↩︎
  38. PX4 Flight Modes (https://dev.px4.io/en/concept/flight_modes.html↩︎
  39. Mavlink (https://mavlink.io/en/↩︎
  40. Mavlink Common.xml (https://mavlink.io/en/messages/common.html↩︎
  41. (http://wiki.ros.org/sensor_msgs↩︎
  42. sensor_msgs/Range (http://docs.ros.org/melodic/api/sensor_msgs/html/msg/Range.html↩︎
  43. std_srvs/Trigger (http://docs.ros.org/melodic/api/std_srvs/html/srv/Trigger.html↩︎
  44. sensor_msgs/BatteryState (http://docs.ros.org/api/sensor_msgs/html/msg/BatteryState.html↩︎
  45. (http://docs.ros.org/api/trajectory_msgs/html/msg/MultiDOFJointTrajectory.html↩︎
  46. mav_msgs/RollPitchYawrateThrust (http://docs.ros.org/indigo/api/mav_msgs/html/msg/RollPitchYawrateThrust.html↩︎
  47. mav_msgs/AttitudeThrust (http://docs.ros.org/jade/api/mav_msgs/html/msg/AttitudeThrust.html↩︎
  48. mav_msgs/RateThrust (http://docs.ros.org/jade/api/mav_msgs/html/msg/RateThrust.html↩︎
  49. (http://wiki.ros.org/sensor_msgs↩︎
  50. odometry (http://www.ros.org/doc/api/nav_msgs/html/msg/Odometry.html↩︎
