ROS 2 Releases and Target Platforms
This REP defines the timeline for future ROS 2 releases as well as the targeted platforms for each specific one. We define platforms to include both operating system releases (e.g. Ubuntu Xenial (16.04 LTS)) as well as major language releases (e.g. Python 3.5). The target platforms represent the set on which all core stacks are expected to work. Exceptions can be made for stacks that are intentionally platform-specific.
Release Schedule
:::: note ::: title Note :::
The following applies to ROS 2 releases after Foxy. Prior to Foxy, releases were made more frequently but with shorter support due to the fact that many foundational parts of ROS 2 were still being heavily developed. ::::
Frequency
New ROS 2 releases will be published in a time based fashion every 12 months. The rationale is that a shorter cycle (like 6 months) results in significant overhead and potentially many active releases at the same time (assuming they have the same support length). On the other hand a longer cycle (like 2 years) is too long for users to wait for new features to be available in a ROS 2 release.
Targeted Platforms
Since regular Ubuntu releases are only supported for 9 months ROS 2 will not target those. A single ROS 2 distribution will only have full Tier 1 support for a single Ubuntu LTS. The rationale is that fully supporting two LTS versions - which means 2-year-different versions of upstream dependencies - is a tremendous overhead and sometimes even impossible. On a case-by-case basis, a ROS 2 distribution may support an older Ubuntu LTS distribution as a Tier 3, community-supported platform.
Since macOS (or at least brew) as well as Windows are rolling platforms we aim to support the latest version available at the time of a ROS 2 distribution release. For Debian we also aim to target the latest stable version though if that version is two years behind the Ubuntu version that might not be possible.
Support
LTS releases
Since Ubuntu LTS releases come with 5 years of standard support we aim to match the same duration. In even years new ROS 2 releases will happen one month after the Ubuntu LTS has been released (which usually means a ROS 2 release in May). The ROS 2 release will be supported until the end of the standard support of the Ubuntu LTS release which is 4 years and 11 months from the ROS 2 release date.
Non-LTS Releases
In order to provide frequent releases to the community, in odd years a non-LTS ROS 2 release will be published. It will always target the same Ubuntu LTS as the previous ROS 2 LTS release but will only be supported for 1.5 years. This duration ensures that the non-LTS will overlap with the next ROS LTS release by 6 months to provide a long enough transition window.
Releases and support duration
  • May 2021: G Turtle: non-LTS release, supported for 1.5 years
  • May 2022: H Turtle: LTS release, supported for 5 years
  • May 2023: I Turtle: non-LTS release, supported for 1.5 years
  • May 2024: J Turtle: LTS release, supported for 5 years
  • and so on, alternating annually between LTS and non-LTS releases
Support Tiers
Platforms are defined as a combination of the OS, the architecture, and the RMW implementation. By default the tiers are expected to apply up to the desktop variant in a rosdistro, unless otherwise specified. ROS 2 variants are defined in REP 20011.
Tier 1
Tier 1 platforms are subjected to our unit test suite and other testing tools on a frequent basis including continuous integration jobs, nightly jobs, packaging jobs, and performance testing. Errors or bugs discovered in these platforms are prioritized for correction by the development team. Significant errors discovered in Tier 1 platforms can impact release dates and we strive to resolve all known high priority errors in Tier 1 platforms prior to new version releases.
Tier 2
Tier 2 platforms are subject to periodic CI testing which runs both builds and tests with publicly accessible results. The CI is expected to be run at least within a week of relevant changes for the current state of the ROS distribution. Package-level binary packages may not be provided but providing a downloadable archive of the built workspace is encouraged. Errors may be present in released product versions for Tier 2 platforms. Known errors in Tier 2 platforms will be addressed subject to resource availability on a best effort basis and may or may not be corrected prior to new version releases. One or more entities should be committed to continuing support of the platform.
Tier 3
Tier 3 platforms are those for which community reports indicate that the release is functional. The development team does not run the unit test suite or perform any other tests on platforms in Tier 3. Installation instructions should be available and up-to-date in order for a platform to be listed in this category. Community members may provide assistance with these platforms.
Platforms by Distribution
If planned support for a target platform is changed, notice will be sent to discourse to enable discussion of this issue.
Ardent Apalone (December 2017 - December 2018)
Required support
ArchitectureUbuntu Xenial (16.04)MacOS Sierra (10.12)Windows 10 (VS2015)
amd64XXX
arm64X
Minimum language requirements:
  • C112
  • C++14
  • Python 3.5
Dependency Requirements:
PackageUbuntu XenialMacOS**Windows 10**
CMake3.5.13.11.03.10.2
EmPY3.3.23.6.53.3.2
Ogre1.10*1.10*1.10*
OpenCV2.4.93.4.12.4.13.2*
Poco1.7.7*1.7.7*1.7.7*
Python3.5.13.6.53.6.4
Qt5.5.15.10.05.10.0
Linux only (used for turtlebot demo)
PCL1.7.2N/AN/A
" * " means that this is not the upstream version (available on the official Operating System repositories) but a package distributed by OSRF or the community (package built and distributed on custom repositories).
" ** " Rolling distributions will see multiple version changes of these dependencies during their lifetime.
This document only captures the version at the first release of a ROS distribution and will not be updated as the dependencies move forward. These versions are thus a low watermark.
Package manager use for dependencies:
  • Ubuntu Xenial: apt
  • MacOS: Homebrew, pip
  • Windows: Chocolatey, pip
Build System Support:
  • ament_cmake
  • cmake
  • setuptools
Middleware Implementation Support:
  • eProsima Fast-RTPS
  • RTI Connext
  • ADLINK OpenSplice
Bouncy Bolson (June 2018 - June 2019)
Targeted platforms:
 Required SupportRecommended Support
ArchitectureUbuntu Bionic (18.04)MacOS Sierra (10.12)Windows 10 (VS2017)Ubuntu Xenial (16.04) [s]Debian Stretch (9) [s]
amd64XXXX [s]X [s]
arm64X  X [s]X [s]
" [s] " Compilation from source, the ROS buildfarm will not produce any binary packages for these platforms.
  • C113
  • C++14
  • Python 3.5
PackageUbuntu BionicMacOS**Windows 10**Ubuntu Xenial [s]Debian Stretch [s]
CMake3.10.23.11.03.10.23.5.13.7.2
EmPY3.3.23.6.53.3.23.3.23.3.2
Ogre1.10*1.10*1.10*1.10*1.10*
OpenCV3.2.03.4.13.4.1*2.4.93.2*
Poco1.8.01.9.01.8.0*1.8.0*1.8.0*
Python3.6.53.6.53.6.53.5.13.5.3
Qt5.9.55.10.05.10.05.5.15.7.1
PCL1.8.1N/AN/A1.7.21.8.0
  • Ubuntu Bionic: apt
  • Ubuntu Xenial, Debian Stretch: apt
  • ament_cmake
  • cmake
  • setuptools
  • RTI Connext
  • ADLINK OpenSplice
Crystal Clemmys (December 2018 - December 2019)
Targeted platforms:
ArchitectureUbuntu Bionic (18.04)MacOS Sierra (10.12)Windows 10 (VS2017)Ubuntu Xenial (16.04)Debian Stretch (9)
amd64Tier 1 [d][a][s]Tier 1 [a][s]Tier 1 [a][s]Tier 2 [s]Tier 3 [s]
arm64Tier 1 [d][a][s]  Tier 2 [s]Tier 3 [s]
The following indicators show what delivery mechanisms are available for each platform.
" [d] " Debian packages will be provided for this platform for packages submitted to the rosdistro.
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Crystal ROS 2 repos file4.
" [s] " Compilation from source.
Middleware LibraryMiddleware ProviderSupport LevelPlatformsArchitectures
rmw_fastrtps_cpp*eProsima Fast-RTPSTier 1All PlatformsAll Architectures
rmw_connext_cppRTI ConnextTier 1All Platforms except DebianAll Architectures except arm64
rmw_opensplice_cppADLINK OpenSpliceTier 2All Platforms except DebianAll Architectures
rmw_fastrtps_dynamic_cppeProsima Fast-RTPSTier 2All PlatformsAll Architectures
rmw_connext_dynamic_cppRTI ConnextTier 2All platforms except DebianAll architectures except arm64
" * " means default RMW implementation.
Middleware implementation support is dependent upon the platform support tier. For example a Tier 1 middleware implementation on a Tier 2 platform can only receive Tier 2 support.
  • C115
  • C++14
  • Python 3.5
CMake3.10.23.13.33.13.33.5.13.7.2
EmPY3.3.23.3.23.3.23.3.23.3.2
Gazebo9.0.09.9.0N/A9.9.0*9.8.0*
Ogre1.10*
OpenCV3.2.04.0.13.4.1*2.4.93.2*
OpenSSL1.1.0g1.0.2q1.0.2q1.0.2g1.1.0j
Python3.6.53.7.23.7.23.5.13.5.3
Qt5.9.55.12.05.10.05.5.15.7.1
 Linux only
RMW DDS Middleware Providers
Connext DDS5.3.1N/A
Fast-RTPS1.7.0
OpenSplice6.9.181127OSS
  • Ubuntu, Debian: apt
  • ament_cmake
  • cmake
  • setuptools
Dashing Diademata (May 2019 - May 2021)
Targeted platforms:
ArchitectureUbuntu Bionic (18.04)MacOS Sierra (10.12)Windows 10 (VS2019)Debian Stretch (9)OpenEmbedded / webOS OSE
amd64Tier 1 [d][a][s]Tier 1 [a][s]Tier 1 [a][s]Tier 3 [s]
arm64Tier 1 [d][a][s]  Tier 3 [s]Tier 3 [s]
arm32Tier 2 [a][s]  Tier 3 [s]Tier 3 [s]
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Dashing ROS 2 repos file6.
rmw_connext_cppRTI ConnextTier 1All Platforms except Debian and OpenEmbeddedAll Architectures except arm64/arm32
rmw_cyclonedds_cppEclipse Cyclone DDSTier 2All PlatformsAll Architectures
rmw_opensplice_cppADLink OpenSpliceTier 2All Platforms except Debian and OpenEmbeddedAll Architectures
  • C++14
  • Python 3.5
PackageUbuntu BionicMacOS**Windows 10**Debian StretchOpenEmbedded**
CMake3.10.23.14.43.14.43.7.23.16.1 / 3.12.2***
EmPY3.3.2
Gazebo9.0.09.9.0N/A9.8.0*N/A
Ogre1.10*N/A
OpenCV3.2.04.1.03.4.6*3.2*4.1.0 / 3.2.0***
OpenSSL1.1.0g1.0.2r1.0.2r1.1.0j1.1.1d / 1.1.1b***
Poco1.8.01.9.01.8.0*1.8.0*1.9.4
Python3.6.53.7.33.7.33.5.33.8.2 / 3.7.5***
Qt5.9.55.12.35.10.05.7.15.14.1 / 5.12.5***
 Linux only
PCL1.8.1N/AN/A1.8.01.8.1
Connext DDS5.3.1N/A
Cyclone DDS0.7.x (Coquette)
Fast-RTPS1.8.0
OpenSplice6.9.190403OSSN/A
" ** " Rolling distributions will see multiple version changes of these dependencies during their lifetime. The versions shown for OpenEmbedded are those provided by the 3.1 Dunfell release series; the versions provided by the other supported release series are listed here: https://github.com/ros/meta-ros/wiki/Package-Version-Differences . Note that the OpenEmbedded releases series for which a ROS distro has support will change during its support time frame, as per the OpenEmbedded support policy shown here: https://github.com/ros/meta-ros/wiki/Policies#openembedded-release-series-support . However, it will always be supported by least one stable OpenEmbedded release series.
" *** " webOS OSE provides this different version.
  • OpenEmbedded: opkg
  • ament_cmake
  • cmake
  • setuptools
Eloquent Elusor (November 2019 - November 2020)
Targeted platforms:
ArchitectureUbuntu Bionic (18.04)MacOS Mojave (10.14)Windows 10 (VS2019)Debian Buster (10)OpenEmbedded / webOS OSE
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Eloquent ROS 2 repos file7.
rmw_opensplice_cppADLINK OpenSpliceTier 2All Platforms except Debian and OpenEmbeddedAll Architectures
  • C++14
  • Python 3.6
PackageUbuntu BionicMacOS**Windows 10**Debian BusterOpenEmbedded**
CMake3.10.23.14.43.14.43.13.43.16.1 / 3.12.2****
EmPY3.3.2
Ogre1.10*N/A
OpenCV3.2.04.1.03.4.6*3.2.04.1.0 / 3.2.0****
OpenSSL1.1.0g1.0.2r1.0.2r1.1.1c1.1.1d / 1.1.1b****
Poco1.8.01.9.01.8.0*1.9.01.9.4
Python3.6.53.7.33.7.33.7.33.8.2 / 3.7.5****
Qt5.9.55.12.35.10.05.11.35.14.1 / 5.12.5****
 Linux only
PCL1.8.1N/AN/A1.9.11.8.1
Connext DDS5.3.1***N/A
Fast-RTPS1.9.0
OpenSplice6.9.190705OSSN/A
" *** " It is anticipated that this will be increased to Connext DDS 6.0.0 pending migration patches8.
" **** " webOS OSE provides this different version.
  • ament_cmake
  • cmake
  • setuptools
Foxy Fitzroy (May 2020 - May 2023)
Targeted platforms:
ArchitectureUbuntu Focal (20.04)MacOS Mojave (10.14)Windows 10 (VS2019)Debian Buster (10)OpenEmbedded / webOS OSE
arm32Tier 3 [s]  Tier 3 [s]Tier 3 [s]
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Foxy ROS 2 repos file9.
rmw_cyclonedds_cppEclipse Cyclone DDSTier 1All PlatformsAll Architectures
rmw_gurumdds_cppGurumNetworks GurumDDSTier 3Ubuntu and WindowsAll Architectures except arm32
  • C++14
  • Python 3.7
PackageUbuntu FocalMacOS**Windows 10**Debian BusterOpenEmbedded**
CMake3.16.33.14.43.14.43.13.43.16.1 / 3.12.2****
EmPY3.3.2
Gazebo11.0.0*11.0.0N/A11.0.0*N/A
IgnitionCitadel*N/ACitadel*N/A
Ogre1.10*N/A
OpenCV4.2.04.2.03.4.6*3.2.04.1.0 / 3.2.0****
OpenSSL1.1.1d1.1.1f1.1.1f1.1.1d1.1.1d / 1.1.1b****
Poco1.9.21.9.01.8.0*1.9.01.9.4
Python3.8.03.8.23.8.03.7.33.8.2 / 3.7.5****
Qt5.12.55.12.35.10.05.11.35.14.1 / 5.12.5****
 Linux only
PCL1.10.0N/AN/A1.9.11.10.0
Connext DDS5.3.1N/A
Fast-RTPS2.0.x
Gurum DDS2.7.xN/A2.7.xN/A
  • ament_cmake
  • cmake
  • setuptools
Galactic Geochelone (May 2021 - November 2022)
Targeted platforms:
ArchitectureUbuntu Focal (20.04)Windows 10 (VS2019)RHEL 8macOSDebian Bullseye (11)OpenEmbedded / webOS OSE
amd64Tier 1 [d][a][s]Tier 1 [a][s]Tier 2 [d][a][s]Tier 3 [s]Tier 3 [s]
" [d] " Distribution-specific (Debian, RPM, etc.) packages will be provided for this platform for packages submitted to the rosdistro.
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Galactic ROS 2 repos file10.
rmw_cyclonedds_cpp*Eclipse Cyclone DDSTier 1All PlatformsAll Architectures
rmw_fastrtps_cppeProsima Fast-DDSTier 1All PlatformsAll Architectures
rmw_connextddsRTI ConnextTier 1Ubuntu, Windows, and macOSAll Architectures except arm64
rmw_fastrtps_dynamic_cppeProsima Fast-DDSTier 2All PlatformsAll Architectures
  • C++17
  • Python 3.6
PackageUbuntu FocalWindows 10**RHEL 8macOS**Debian BullseyeOpenEmbedded**
CMake3.16.33.19.13.18.23.14.43.18.43.16.1 / 3.12.2****
EmPY3.3.2
Gazebo11.0.0*N/AN/A11.0.011.0.0*N/A
IgnitionEdifice*N/AN/AEdifice*Edifice*N/A
Ogre1.10*N/A
OpenCV4.2.03.4.6*3.4.64.2.04.5.14.1.0 / 3.2.0****
OpenSSL1.1.1d1.1.1i1.1.1g1.1.1f1.1.1i1.1.1d / 1.1.1b****
Python3.8.03.8.33.6.83.8.23.9.13.8.2 / 3.7.5****
Qt5.12.55.12.105.12.55.12.35.15.25.14.1 / 5.12.5****
 Linux only
PCL1.10.0N/A1.11.1N/A1.11.11.10.0
Cyclone DDS0.8.x (Réplique)
Fast-DDS2.3.x
Connext DDS5.3.1N/A5.3.1N/A
Gurum DDS2.7.xN/A
  • macOS: Homebrew, pip
  • RHEL: dnf
  • ament_cmake
  • cmake
  • setuptools
Humble Hawksbill (May 2022 - May 2027)
Targeted platforms:
ArchitectureUbuntu Jammy (22.04)Windows 10 (VS2019)RHEL 8Ubuntu Focal (20.04)macOSDebian Bullseye (11)OpenEmbedded / Yocto Project
amd64Tier 1 [d][a][s]Tier 1 [a][s]Tier 2 [d][a][s]Tier 3 [s]Tier 3 [s]Tier 3 [s]Tier 3 [s]
arm64Tier 1 [d][a][s]  Tier 3 [s] Tier 3 [s]Tier 3 [s]
arm32Tier 3 [s]  Tier 3 [s] Tier 3 [s]Tier 3 [s]
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Humble ROS 2 repos file11.
rmw_fastrtps_cpp*eProsima Fast-DDSTier 1All PlatformsAll Architectures
  • C++17
  • Python 3.6
PackageUbuntu JammyWindows 10**RHEL 8Ubuntu FocalmacOS**Debian BullseyeOpenEmbedded**
CMake3.22.13.22.03.20.23.16.33.14.43.18.43.22.3 / 3.16.5***
EmPY3.3.43.3.2
Gazebo Classic11.x.x*N/AN/A11.0.0*11.x.x11.x.x*N/A
Gazebo (Ignition)Fortress*N/AN/AFortress*Fortress*Fortress*N/A
NumPy1.21.51.18.41.14.31.17.41.18.41.19.5N/A
Ogre1.12.1*N/A
OpenCV4.5.43.4.6*3.4.64.2.04.2.04.5.14.1.0 / 3.2.0***
OpenSSL1.1.1l1.1.1l1.1.1k1.1.1d1.1.1f1.1.1i1.1.1d / 1.1.1b***
Python3.10.43.8.33.6.83.8.03.8.23.9.13.8.2 / 3.7.5***
Qt5.15.35.12.125.15.25.12.55.12.35.15.25.14.1 / 5.12.5***
 Linux only
PCL1.12.1N/A1.11.11.10.0N/A1.11.11.10.0
Cyclone DDS0.9.x (Papillons)
Fast-DDS2.6.x
Connext DDS6.0.1N/A6.0.1N/A
" ** " means that the dependency may see multiple version changes, because the dependency uses a package manager that continually updates the dependency without a stable API.
  • RHEL: dnf
  • ament_cmake
  • cmake
  • setuptools
Iron Irwini (May 2023 - November 2024)
Targeted platforms:
ArchitectureUbuntu Jammy (22.04)Windows 10 (VS2019)RHEL 9macOSDebian Bullseye (11)OpenEmbedded / Yocto Project
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Iron ROS 2 repos file12.
  • C++17
  • Python 3.8
PackageUbuntu JammyWindows 10**RHEL 9macOS**Debian BullseyeOpenEmbedded**
CMake3.22.13.22.03.20.23.14.43.18.43.22.3 / 3.16.5***
EmPY3.3.43.3.23.3.43.3.2
Gazebo Classic11.x.x*N/AN/A11.x.x11.x.x*N/A
Gazebo (Ignition)Fortress*N/AN/AFortress*Fortress*N/A
NumPy1.21.51.18.41.20.11.18.41.19.5N/A
Ogre1.12.1*N/A
OpenCV4.5.43.4.6*4.6.04.2.04.5.14.1.0 / 3.2.0***
OpenSSL3.0.21.1.1l3.0.11.1.1f1.1.1i1.1.1d / 1.1.1b***
Python3.10.63.8.33.9.143.10.83.9.13.8.2 / 3.7.5***
Qt5.15.35.12.125.15.35.12.35.15.25.14.1 / 5.12.5***
 Linux only
PCL1.12.1N/A1.12.0N/A1.11.11.10.0
RMW DDS Middleware
Cyclone DDS0.9
Fast-DDS2.8
Connext DDS6.0.1N/A
Gurum DDS2.8.xN/A
  • RHEL: dnf
  • ament_cmake
  • cmake
  • setuptools
Jazzy Jalisco (May 2024 - May 2029)
Targeted platforms:
ArchitectureUbuntu Noble (24.04)Windows 10 (VS2019)RHEL 9Ubuntu Jammy (22.04)macOSDebian Bookworm (12)OpenEmbedded / Yocto Project
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Jazzy ROS 2 repos file13.
  • C++17
  • Python 3.8
PackageUbuntu NobleWindows 10**RHEL 9Ubuntu JammymacOS**Debian BookwormOpenEmbedded**
CMake3.28.33.22.03.20.23.22.13.20.03.25.13.22.3
EmPY3.3.43.3.23.3.4
GazeboHarmonic*N/AN/AHarmonic*Harmonic*Harmonic*N/A
NumPy1.26.41.18.41.20.11.21.51.18.41.24.2N/A
Ogre1.12.10N/A
OpenCV4.6.03.4.6*4.6.04.5.44.2.04.6.04.1.0 / 3.2.0***
OpenSSL3.0.131.1.1l3.0.71.1.1l1.1.1f3.0.111.1.1d / 1.1.1b***
Python3.12.33.8.33.9.163.10.43.10.83.11.23.8.2 / 3.7.5***
Qt5.15.105.12.125.15.35.15.35.12.35.15.85.14.1 / 5.12.5***
 Linux only
PCL1.14.0N/A1.12.01.12.1N/A1.13.01.10.0
RMW DDS Middleware
Cyclone DDS0.10.4
Fast-DDS2.14.0
Connext DDS6.0.1N/A
Gurum DDS4.2.0N/A
  • Ubuntu, Debian: apt, pip
  • RHEL: dnf
  • ament_cmake
  • cmake
  • setuptools
Kilted Kaiju (May 2025 - November 2026)
Targeted platforms:
ArchitectureUbuntu Noble (24.04)Windows 10 (VS2019)RHEL 9macOSDebian Bookworm (12)OpenEmbedded / Yocto Project
" [a] " Binary releases are provided as a single archive per platform containing all packages in the Jazzy ROS 2 repos file14.
rmw_zenoh_cppEclipse ZenohTier 1All PlatformsAll Architectures
  • C++17
  • Python 3.9
PackageUbuntu NobleWindows 10**RHEL 9macOS**Debian BookwormOpenEmbedded**
CMake3.28.33.28.33.26.53.31.13.25.13.22.3
EmPY3.3.43.3.43.3.4a3.3.4
GazeboIonic*N/AN/AIonic*Ionic*N/A
NumPy1.26.41.26.41.20.12.1.31.24.2N/A
Ogre1.12.10N/A
OpenCV4.6.04.9.04.6.04.10.04.6.04.1.0 / 3.2.0***
OpenSSL3.0.133.3.23.2.21.1.1w3.0.151.1.1d / 1.1.1b***
Python3.12.33.12.33.9.193.13.03.11.23.8.2 / 3.7.5***
Qt5.15.135.15.85.15.95.15.165.15.85.14.1 / 5.12.5***
 Linux only
PCL1.14.0N/A1.12.01.14.11.13.01.10.0
RMW Middleware
Connext DDS7.3.0.0N/A
Cyclone DDS0.10.5
Fast-DDS2.14.4
Gurum DDS4.2.0N/A
Zenoh1.0.4
  • Windows: pixi/conda, pip
  • RHEL: dnf
  • ament_cmake
  • cargo
  • cmake
  • setuptools
Rolling Ridley (June 2020 - Ongoing)
Rolling Ridley is a rolling development distribution of ROS 2 as described in REP-200215.
The target platform for Rolling Ridley will update as new upstream distributions are selected for ROS 2 development. As of May 2025, Rolling Ridley targets the same platforms as ROS 2 Kilted Kaiju.
This document is provided to help plan future development for libraries. The primary platforms for ROS 2 are Canonical's Ubuntu releases, and our intent is to track these releases as best as possible while also allowing for current, thirdparty libraries to be used. macOS and Windows being rolling distributions, ROS 2 will target the latest state of these distributions at the time of the release.
Target platforms for future releases are speculative and are based on consulting Ubuntu's release and end-of-life schedule16.
  1. REP 2001 (http://www.ros.org/reps/rep-2001.html↩︎
  2. C11 is required, but support for some non-compliant systems is also provided, e.g. MSVC. ↩︎
  3. C11 is required, but support for some non-compliant systems is also provided, e.g. MSVC. ↩︎
  4. Crystal ROS 2 Repos File (https://github.com/ros2/ros2/blob/crystal/ros2.repos↩︎
  5. C11 is required, but support for some non-compliant systems is also provided, e.g. MSVC. ↩︎
  6. Dashing ROS 2 Repos File (https://github.com/ros2/ros2/blob/dashing/ros2.repos↩︎
  7. Eloquent ROS 2 Repos File (https://github.com/ros2/ros2/blob/eloquent/ros2.repos↩︎
  8. Connext DDS 6.0.0 Support (https://github.com/ros2/rmw_connext/issues/375↩︎
  9. Foxy ROS 2 Repos File (https://github.com/ros2/ros2/blob/foxy/ros2.repos↩︎
  10. Galactic ROS 2 Repos File (https://github.com/ros2/ros2/blob/galactic/ros2.repos↩︎
  11. Humble ROS 2 Repos File (https://github.com/ros2/ros2/blob/humble/ros2.repos↩︎
  12. Iron ROS 2 Repos File (https://github.com/ros2/ros2/blob/iron/ros2.repos↩︎
  13. Jazzy ROS 2 Repos File (https://github.com/ros2/ros2/blob/jazzy/ros2.repos↩︎
  14. Kilted ROS 2 Repos File (https://github.com/ros2/ros2/blob/rolling/ros2.repos↩︎
  15. REP 2002 (http://www.ros.org/reps/rep-2002.html↩︎
  16. Ubuntu Releases with End-of-Life Dates (https://wiki.ubuntu.com/Releases↩︎
