Python 3 Support
Python 3 Support
Outline
  1. Abstract
  2. Motivation
  3. Context
  4. Proposal
  5. References
  6. Copyright
This REP describes the path for switching from Python 2 to Python 3 in ROS 1.
As described in the Python release schedule1 Python 2.7 will only receive bugfix releases until 2020. As a consequence Ubuntu is trying to demote Python 2.7 into the [universe]{.title-ref} repository2. While it is unlikely that Python 2.7 will be removed from the archives entirely, it should not be relied on past its EOL date. Therefore ROS 1 must move to Python 3.
Context
Past proposals for Python 3 support have assumed a ROS distro will need to support Python 2 and Python 3 at the same time. Since then it was decided the first ROS 1 distribution to support Python 3 will be Noetic Ninjemys (May 2020)3, and it will only support Python 3. This REP only describes the current proposal since the change in requirements has made past proposals obsolete. All ROS packages containing Python code need to support Python 3 before they can be released into Noetic.
This proposal does not specify a minimum minor version for Python. The minimum version will be defined in REP 34 together with all other versions.
Proposal
Python 3 support at the time of Noetic release means:
  • All ROS tooling supports creating a Python 3 only ROS distro
  • All ROS packages released to Noetic support Python 3
The amount of work to transition to Python 3 is expected to be significant. The entire ROS community will need to share the workload. This effort should be started as soon as possible to reduce the risk of the Noetic release being delayed.
Tooling support for Python 3
rosdep keys
Some Python rosdep keys have <platform>_python3 entries. This was an experiment at having a rosdep key conditionally evaluate to either a Python 2 or Python 3 system dependency. No new <platform>_python3 entries should be added, and the entries should not be relied on.
All existing Python rosdep keys including <platform>_python3 entries will stay the same to avoid breaking unknown existing use cases. Even if a key refers to a Python 2 package on one platform and Python 3 on another, it should stay that way.
For new Python keys, when a platform has separate Python 2 and Python 3 versions of a package, there should be a rosdep key for each. For example, consider the two keys python-catkin-pkg and python3-catkin-pkg. The python-catkin-pkg key should resolve to a Python 2 dependency on any platform where one exists, while python3-catkin-pkg should only resolve to a Python 3 dependency.
ROS_PYTHON_VERSION
ROS_PYTHON_VERSION is an environment variable that is set to either 2 or 3 to indicate the major version of Python supported by a ROS distro. The intent is to allow package.xml files to have conditional Python dependencies.
It is set by the package ros_environment when sourcing a ROS workspace. The version set will be dictated by REP 35. For example, in Melodic it defaults to 2, but in Noetic it must be 3.
Users building ROS from source will not have an existing ROS workspace set, so the variable won't be set, and conditional dependencies can't be evaluated when using rosdep to install them. To fix this, rosdep will set ROS_PYTHON_VERSION. It must choose a Python version to match the ROS distro while allowing platforms that already use Python 3 to override it
The choice is made using the following information:
  • the command line option --rosdistro
  • the environment variable ROS_DISTRO
  • the environment variable ROS_PYTHON_VERSION
  • the value python_version in the ROS distribution file6
  • the version of Python used to invoke rosdep via sys.version[0]
If --rosdistro is set then the value of python_version in the ROS distro file is used. For the purpose of evaluating conditional dependencies, ROS_PYTHON_VERSION will be set to python_version, and ROS_DISTRO will be set to the value passed in via --rosdistro. This allows users who may be unaware they have an existing ROS workspace sourced to install dependencies for a different ROS distro.
Otherwise, if ROS_PYTHON_VERSION is set then that value is used. The value of ROS_DISTRO is unchanged whether it is set or unset. This allows users to install dependencies for a ROS distro with a different Python version than the ROS distro targets, such as Arch Linux users using Python 3 for ROS Melodic.
If ROS_PYTHON_VERSION is not set but ROS_DISTRO is then for the purpose of evaluating conditional dependencies ROS_PYTHON_VERSION will be set to the value of python_version. This makes sure ROS_PYTHON_VERSION dependencies get evaluated in a way that matches the desired distro. This case should not happen so long as the user has sourced a workspace with the ros_environment package, since that package sets both ROS_DISTRO and ROS_PYTHON_VERSION.
Finally, if none of --rosdistro, ROS_DISTRO or ROS_PYTHON_VERSION are set then for the purpose of evaluating conditional dependencies ROS_PYTHON_VERSION will be set to sys.version[0]. This makes sure ROS_PYTHON_VERSION dependencies are not silently ignored, though there is a risk of installing the wrong packages.
rosdep and pip packages
Unlike Debian packages, keys that resolve to packages on PyPI may refer to either Python 2 or Python 3 dependencies. The version that gets downloaded depends on the version of Python used to invoke pip. Rosdep currently calls the command pip. It might use Python 2 when using the Debian package python-pip, but it could use Python 3 inside a venv. rosdep should pick a version of pip that matches ROS_PYTHON_VERSION regardless of whether a Python virtual env is being used.
First rosdep will try the commands pip2 or pip3 since those are similar to the previous usage of pip. If those don't exist and sys.version[0] is the same value as ROS_PYTHON_VERSION then it will try sys.executable -m pip. If that didn't work, then as a last resort it will try the commands python2 -m pip or python3 -m pip.
ROS packages support for Python 3
There are many ROS packages using Python that will need to be modified to support Python 3. Packages using different branches for different ROS distros can drop support for Python 2 in their Noetic branch. Packages which use the same branch in multiple ROS distros may need to support both Python 2 and Python 3 at the same time. This section describes what needs to be done in both cases.
Shebangs and reliance on the Python command
Python scripts on UNIX systems typically have shebang lines written as:
##!/usr/bin/env python
PEP 394 recommends distributed Python scripts to use either python2 or python37. The python command cannot be trusted to a specific Python version. On older ROS distros, scripts can continue to use python since they're known to work on those platforms. These shebangs must be rewritten to the specific version of Python supported. Packages can use the CMake macro catkin_install_python() to install Python scripts with rewritten shebangs. It will create a relay script in the devel space with a rewritten shebang.
The same issue appears in scripts that call the python command directly. If they are Python scripts, they should invoke sys.executable. Otherwise, they should invoke the specific version of Python they require, which means templating the script to invoke the Python interpreter found when the package was built.
Dependencies and package.xml
On platforms where the target version of Python is 2, the package.xml of a ROS package must refer to Python 2 dependencies, and when the target Python version is 3 it must refer to Python 3 dependencies. Packages which release from different branches for each ROS distro can replace rosdep keys that resolve to Python 2 dependencies with ones that resolve to Python 3 equivalents. Packages using the same code base for multiple ROS distros should instead use conditional dependencies as described in REP 1498.
<depend condition="$ROS_PYTHON_VERSION == '2'">python-numpy</depend>
<depend condition="$ROS_PYTHON_VERSION == '3'">python3-numpy</depend>
If ROS_PYTHON_VERSION is relied upon at build time, such as when using catkin_install_python() to rewrite shebangs, then the package must declare a <buildtool_depend> on ros_environment. Any ROS package which uses ROS_PYTHON_VERSION in a script intended to be run at runtime should add an <exec_depend> tag for ros_environment.
Making Python fixes available to downstream packages
Transitioning to Python 3 is expected to be a significant effort. Maintainers should release packages with Python 3 fixes to Noetic as soon as possible, even if they intend to make breaking changes later. Maintainers should also add source entries for their Noetic branches to this file to enable downstream users to use rosinstall_generator with the --upstream-development flag to get Python 3 fixes. Instructions to build from source using Python 3 have been made available to the ROS community9.
Organizing community effort
In order to achieve this, prior to the Noetic release community members must be able to see:
  • which ROS packages already support Python 3
  • which ROS packages need help supporting Python 3
The presence of a source entry in the Noetic distribution.yaml should be taken to mean a package has started transitioning to Python 3. Community members can use the differences between this and the previous ROS distro's distribution.yaml as an indication of which packages would benefit the most from their contributions via the Blocked Releases10 or Blocked Source Entries11 pages.
There are many ROS package maintainers in the community, and each has the responsibility of deciding how the packages they maintain should make the transition to Python 3. On an individual repository level, community members are encouraged to open issues and pull requests with Python 3 fixes.
  1. PEP 373 Python 2.7 Release Schedule (https://www.Python.org/dev/peps/pep-0373/↩︎
  2. Python2 to be demoted to universe (https://bugs.launchpad.net/ubuntu/+source/swift/+bug/1817023↩︎
  3. Planning future ROS 1 distributions (https://discourse.ros.org/t/planning-future-ros-1-distribution-s/6538↩︎
  4. REP-0003 Target Platforms (http://ros.org/reps/rep-0003.html↩︎
  5. REP-0003 Target Platforms (http://ros.org/reps/rep-0003.html↩︎
  6. REP 153 ROS distribution files (http://ros.org/reps/rep-0153.html↩︎
  7. PEP 394 The "Python" Command on Unix-Like Systems (https://www.Python.org/dev/peps/pep-0394/↩︎
  8. REP-0149 Package Manifest Format Three Specification (http://ros.org/reps/rep-0149.html↩︎
  9. Transitioning to Python 3 (http://wiki.ros.org/UsingPython3/↩︎
  10. Noetic Blocked Releases (http://repositories.ros.org/status_page/blocked_releases_noetic.html↩︎
  11. Noetic Blocked Source Entries (http://repositories.ros.org/status_page/blocked_source_entries_noetic.html↩︎
