ROS Melodic and Newer Metapackages
This REP describes the metapackages for the ROS Melodic release and for releases that follow until otherwise replaced by a similar update REP. This REP updates REP 1311 and REP 1422 for changes in packages.
For a discussion on the general motivation and role of variants, please see REP 1083.
As of ROS Hydro we have completed the transition to using metapackages instead of variants. For more information on metapackages see REP 1274.
This document covers the common metapackages used for recommended installations. It is expressed in the ros/metapackages repository on github.com 5.
This REP proposes the same entrypoints as REP 108 and merely updates the variant definitions to reflect the organizational changes in ROS stacks. In particular, in ROS Melodic the [robot]{.title-ref} metapackage is contracted to remove [robot_model]{.title-ref} and instead explicitly list the necessary packages.
The definitions in this REP are more focused and concise for clearer purpose, and do not list all transitive dependencies explicitly.
End-user entry points
We define the same three main entry points for ROS users as REP 108 6.
  • desktop_full (recommended)
  • desktop
  • ros_base
Metapackages
ROS Core
The [ros_core]{.title-ref} metapackage composes the core communication protocols. It may not contain any GUI dependencies.
- ros_core:
     packages: [catkin, class_loader, cmake_modules, common_msgs, gencpp,
                geneus, genlisp, genmsg, gennodejs, genpy, message_generation,
                message_runtime, pluginlib, ros, ros_comm,
                rosbag_migration_rule, rosconsole, rosconsole_bridge,
                roscpp_core, rosgraph_msgs, roslisp, rospack, std_msgs,
                std_srvs]
ROS Base
The [ros_base]{.title-ref} metapackage composes the [ros_core]{.title-ref} metapackage with commonly used libraries. It may not contain any GUI dependencies.
- ros_base:
    extends: [ros_core]
    packages: [actionlib, bond_core, dynamic_reconfigure, nodelet_core]
Robot metapackage
The [robot]{.title-ref} metapackage is defined to be core, stable, ROS libraries for any robot hardware. It is the "general robotics" libraries of ROS. It may not contain any GUI dependencies.
- robot:
    extends: [ros_base]
    packages: [control_msgs, diagnostics, executive_smach, filters, geometry,
               joint_state_publisher, kdl_parser, kdl_parser_py,
               robot_state_publisher, urdf, urdf_parser_plugin, xacro]
Capability variants
The capability variants organize commonly used libraries that are specific to a class of use case. We also define a [simulators]{.title-ref} variant that provides an organizational role for higher-level variants. We discourage GUI dependencies in these stacks, if possible.
- perception:
    extends: [ros_base]
    packages: [image_common, image_pipeline,
               image_transport_plugins, laser_pipeline,
               perception_pcl, vision_opencv]
- simulators:
    extends: [robot]
    packages: [gazebo_ros_pkgs, rqt_common_plugins, rqt_robot_plugins,
               stage_ros]
- viz:
    extends: [ros_base]
    packages: [rqt_common_plugins, rqt_robot_plugins, rviz]
Desktop variants
The [desktop]{.title-ref} variants are main entry points for users. The [desktop_full]{.title-ref} is a "batteries included" experience for users and attempts to collect stable, well-documented libraries. These libraries may be specific to certain classes of robots, such as mobile robots, though they are not specific to a particular robot. The [desktop]{.title-ref} variant is more minimal and only provides the stacks in the [robot]{.title-ref} variant, plus visualization and debugging tools. Both of these variants contain tutorials for the stacks they provide.
- desktop:
    extends: [robot, viz]
    packages: [angles, common_tutorials, geometry_tutorials, joint_state_publisher_gui,
               ros_tutorials, roslint, urdf_tutorial, visualization_tutorials]
- desktop_full:
    extends: [desktop, perception, simulators]
    packages: [urdf_sim_tutorial]
Institution-specific and robot-specific
Please see REP 1087 for discussion of institution-specific metapackages.
When creating robot or institution specific metapackages consider using the *_robot and *_desktop and *_base form where * is the institution or robot name.
An institution is not required to provide a metapackage, they are mainly provided for convenience and identity.
The metapackages in this REP provide the same semantic top level entry points while simplifying the definitions.
  1. REP 131: Groovy Variants (http://www.ros.org/reps/rep-0131.html↩︎
  2. REP 142: Indigo Variants (http://www.ros.org/reps/rep-0142.html↩︎
  3. REP 108: Diamondback Variants (http://www.ros.org/reps/rep-0108.html↩︎
  4. REP 127: Specification of package manifest format (https://ros.org/reps/rep-0127.html↩︎
  5. ROS Metapackages Repository (https://github.com/ros/metapackages↩︎
  6. REP 108: Diamondback Variants (http://www.ros.org/reps/rep-0108.html↩︎
  7. REP 108: Diamondback Variants (http://www.ros.org/reps/rep-0108.html↩︎
