CameraInfo updates for Diamondback
This REP adds support for binning and alternative distortion models to sensors_msgs/CameraInfo. It clarifies the correct interpretation of region of interest (ROI), including how it interacts with binning and distortion.
In this REP, sensor_msgs/CameraInfo acquires binning_x and binning_y fields. The distortion parameter array D is made variable-length, its meaning specified by a string. This REP clarifies ROI to mean the raw image region as captured by the camera and introduces a distinction between raw ROI and rectified ROI. It adds appropriate new methods to the camera model classes in image_geometry, the recommended API for using CameraInfo.
The CameraInfo message is used ubiquitously in ROS vision code and commonly archived in bag files, so it is not to be changed lightly. CameraInfo is based on a well-established mathematical camera model 1. It already works well for by far the most common use case, capturing full-resolution images from a camera with less-than-extreme distortion.
Even so, experience from developing on top of CameraInfo in Box Turtle and C Turtle has revealed several limitations of the current message. There is no support for binning, a common and useful camera feature. The distortion model has room for improvement when it comes to wide angle or fisheye lenses with severe distortion. The existing ROI support in CameraInfo was not adequately thought out, limiting its usefulness in practice.
It's debatable whether any of these issues individually merit a breaking change to CameraInfo. This REP batches together fixes for the major known problems with CameraInfo, so that users need only update code and bag files once. We believe that together these changes represent a significant improvement. We expect the revised CameraInfo to remain stable for at least another 2-3 ROS distributions.
Binning
Binning is the process of summing small neighborhoods of pixels on chip into larger "bins." For example, 2x2 binning reduces the resolution of the camera by half both horizontally and vertically. The chief advantage of binning is to increase the signal to noise ratio (SNR). This is especially useful in low-light environments. A second benefit is that decimating the resolution may allow for increased frame rate.
Giving up resolution for increased SNR and/or frame rate is a useful trade-off in many vision applications. The utility of binning, combined with its wide availability in camera hardware, makes this a particularly valuable feature to support in CameraInfo.
The correct geometric interpretation of a binned image requires scaling the focal lengths and principal point calculated during calibration at full resolution. The current CameraInfo message unfortunately has no way to encode the binning parameters.
Alternate Distortion Models
Currently CameraInfo assumes the "Plumb Bob" model of distortion 2, a 5-parameter polynomial approximation of radial and tangential distortion. Recently OpenCV has added support for an 8-parameter rational polynomial distortion model. This new model offers improved stability and accuracy for wide angle and fisheye lenses, which can severely distort the image. Unfortunately the size of the distortion parameter array D in CameraInfo is fixed at 5, so there is currently no way to support more complex models.
This REP makes D variable-length and introduces a string distortion_model to distinguish which distortion model was used in the calibration. These changes also accommodate adding other distortion models in the future, should we find it necessary.
Region of Interest
Region of interest is another common camera feature, allowing the user to instruct the imager to only capture a desired sub-rectangle of its full resolution. This may be used to reduce bandwidth, particularly with high-definition cameras that could overwhelm a network connection at full resolution. Like binning, it may increase the frame rate for some cameras. Finally, it may improve the imagery of the object we are interested in by applying smart camera features such as auto-exposure only to the relevant image patch.
Applications of ROI to vision include performing high-speed tracking of an object, or acquiring a high-resolution close-up of an object with known location.
CameraInfo already supports ROI in that it contains fields for the sub-rectangle captured by the imager. This ROI is given in raw image coordinates, as supplied to the imager, as that is all the camera driver is expected to know and care about. Given the ROI and the camera calibration, we (or rather image_geometry) can rectify the image patch. But what is the ROI of the rectified patch in rectified coordinates; that is, given the full rectified image, what sub-rectangle inside of it corresponds to the rectified patch?
Currently image_geometry (by extension, image_proc) assumes that the ROI in rectified coordinates is the same as the ROI in raw (unrectified) coordinates. This behavior is broken. For small ROIs and/or large amounts of distortion, the raw patch (once rectified) may not even coincide with the same ROI in rectified coordinates. In that case the rectified image patch is set to all black, as the data required to fill it was not even captured3. Therefore we must introduce a mapping between the ROI in raw coordinates and the corresponding ROI in rectified coordinates.
CameraInfo Message
The proposed CameraInfo message is listed (stripped of comments) below. Additions and changes are noted on the right.
Header header
uint32 seq
time stamp
string frame_id
uint32 height
uint32 width
# roi used to be located here.
# I've moved it to after the calibration parameters.
string distortion_model # New field
float64[] D # Made variable-length
float64[9] K
float64[9] R
float64[12] P
uint32 binning_x # New field
uint32 binning_y # New field
sensor_msgs/RegionOfInterest roi # Moved field
uint32 x_offset
uint32 y_offset
uint32 height
uint32 width
bool do_rectify # New field
Interpretation
There are three parts to CameraInfo.
- ROS header. The time stamp is the time at which the image was captured.
frame_idis the name of the optical coordinate frame with origin at the optical center of the camera. - Calibration parameters. These are fixed during camera calibration. Their values will be the same in all messages until the camera is recalibrated. Note that self-calibrating systems may "recalibrate" frequently.
- Operational parameters. These define the image region actually captured by the camera driver. Although they affect the geometry of the output image, they may be changed freely without recalibrating the camera.
| Calibration Parameters | Operational Parameters |
| height | binning_x |
| width | binning_y |
| D | roi |
| K | |
| R | |
| P |
The height and width fields always contain the image dimensions with which the camera was calibrated; normally this will be the full resolution of the camera.
The arrays of calibration parameters D, K, R and P are interpreted as described in45. D contains the parameters of the model named by the distortion_model string.
Recognized distortion_model names are given in the new header sensor_msgs/distortion_models.h. For Diamondback these will be "plumb_bob" and "rational_polynomial", as described in Alternate Distortion Models. Empty D and distortion_model indicate that the CameraInfo cannot be used to rectify points or images, either because the camera is not calibrated or because the rectified image was produced using an unsupported distortion model, e.g. the proprietary one used by Bumblebee cameras6.
Binning reduces the resolution of the output image to (width / binning_x) x (height / binning_y). Consumers of CameraInfo (such as image_geometry) must scale the focal lengths and principal point of the camera model. Both supported distortion models operate on normalized image coordinates (independent of focal length and principal point), and the rotation matrix R on 3D world coordinates, so binning does not affect these parameters.
For the sake of backwards compatibility, binning_x = binning_y = 0 (the default values) is considered the same as binning_x = binning_y = 1, or no binning.
The ROI is specified in the full (unbinned) image coordinates. For example, the 100x150 sub-rectangle at offset (25, 35) in a 2x2 binned image is represented as a ROI with dimensions 200x300 and offset (50, 70). The ROI specifies a sub-rectangle of pixels on the imager, independent of binning. x_offset and y_offset are the offset from the top-left corner of the full image to the top-left corner of the region of interest.
As a convenience, setting roi.x_offset, roi.y_offset, roi.width and roi.height all to 0 has a special meaning; it is the same as the full resolution. This is especially useful to users of the polled camera interface7, who can request a full resolution image despite not knowing ahead of time what that resolution is. It also means that authors of camera drivers that do not support ROI can safely ignore the CameraInfo/roi fields, which default to 0.
The new field roi.do_rectify is discussed in the next section.
Raw and Rectified ROI
When working with distorted images, a desired raw ROI can be given directly to the camera driver. More commonly, however, the consumer wants the camera to provide an ROI in the rectified image, and does not particularly care how the rectified image patch is acquired. To bridge the gap between user (who works in rectified coordinates) and camera driver (which understands only raw coordinates), we define a mapping between raw and rectified ROI.
Given a rectified ROI, the corresponding raw ROI is the smallest sub-rectangle such that every pixel in the rectified ROI maps to a point inside the raw ROI. In other words, the raw ROI must contain all the information needed to fill the rectified ROI. Geometrically, if we distort the outline of the rectified ROI into raw coordinates, the raw ROI circumscribes the resulting curve.
Likewise, given a raw ROI, the corresponding rectified ROI is the largest sub-rectangle such that every pixel in the rectified ROI maps to a point inside the raw ROI. If we rectify the outline of the raw ROI, the rectified ROI inscribes the resulting curve.
When a full resolution image is captured, the behavior is different. During the camera calibration process, the user chooses a scaling which trades off between having all valid pixels in the rectified image (but discarding some pixels from the raw image) versus discarding no raw image pixels (but permitting invalid pixels in the rectified image). The assumption that all rectified pixels should be valid does not necessarily hold; that is up to the user to decide during calibration. The raw and rectified images have the same resolution, and hence the same "ROI" (the full image). roi.do_rectify is set to False to indicate that no ROI mapping should be done.
When the raw ROI is only part of the full resolution, roi.do_rectify is set to True. The raw ROI is mapped to the rectified ROI as described above.
It is permitted to set roi.do_rectify = False when the ROI is not actually the same as the full image resolution to suppress the ROI mapping. This feature can be useful in special situations, for example if the camera supports particular video modes with the resolution cropped to a smaller field of view. See use case #3 Cropped Video Mode below.
To complete the set of possibilities, the user could request an ROI of the full image resolution but with roi.do_rectify = True. This ensures that the rectified image contains no invalid pixels, but it will also discard pixels from the raw image.
Polled Camera Interface
The polled_camera/GetPolledImage service is updated as below:
string response_namespace
uint32 x_offset
uint32 y_offset
uint32 height
uint32 width
bool success # New field
string status_message # New field
time stamp
This revision allows users to specify the binning as well as the ROI. It also allows the camera driver to return failure (and an explanatory message) if the request could not be met; see Guidelines for Camera Drivers below.
The main purpose of a camera driver is to expose useful functions of the camera hardware. If a camera does not support binning or ROI in hardware, the driver has no obligation to implement these features in software; indeed, that might mislead users as to the camera's actual capabilities. Such post-processing can always be performed by a separate node.
Raw and Rectified ROI described a range of ways in which the ROI fields may be set for different purposes. In practice most camera drivers only need one or two behaviors. When capturing at full resolution, CameraInfo/roi can be left at the default of all zeros to signify full resolution. Drivers that do not support ROI need not touch CameraInfo/roi at all. When the user has requested some ROI (perhaps through dynamic_reconfigure), the driver should set CameraInfo/roi with the ROI offsets and size used and do_rectify = True.
Drivers are not obligated to implement the polled camera interface 8. This feature is most useful for cameras that support software triggering or one-shot capture, and especially high-resolution cameras that may be expensive to stream at full resolution.
If a GetPolledImage request asks for binning settings that the camera does not support, the driver shall return failure (success = False). If the request asks for a ROI that is not full resolution and the camera does not support ROI, or if the requested ROI does not match any available camera resolution, the driver shall return failure. There may be cases when the camera supports ROI but cannot achieve precisely the ROI requested, e.g. if the camera requires the ROI offsets to be multiples of the binning sizes. In that situation the driver should expand the requested ROI to one attainable by the camera, return success, and set CameraInfo/roi to the expanded ROI. roi.do_rectify should always be copied as-is from the request to the output CameraInfo.
image_geometry API
Several new methods will be added to image_geometry's PinholeCameraModel class9. The signatures below are for C++; the Python API will be equivalent.
class PinholeCameraModel
// Resolution of the camera when it was calibrated
cv::Size fullResolution() const;
// Current resolution. May be reduced by binning, or by ROI
// when roi.do_rectify == False
cv::Size currentResolution() const;
// The current binning settings
int binningX() const;
int binningY() const;
// The current raw and rectified ROIs
cv::Rect rawRoi() const;
cv::Rect rectRoi() const;
// Compute the rectified ROI corresponding to a given raw ROI
cv::Rect rectifyRoi(cv::Rect roi_raw) const;
// Compute the raw ROI corresponding to a given rectified ROI.
// The second overload is more convenient for use with the
// polled_camera interface.
cv::Rect unrectifyRoi(cv::Rect roi_rect) const;
void unrectifyRoi(cv::Rect roi_rect,
sensor_msgs::RegionOfInterest& roi_raw) const;
Internally, PinholeCameraModel will be updated to compute the rectified ROI from CameraInfo/roi, and will use it when (un)rectifying points and images.
Use Cases
Here we examine how a camera driver might fill the CameraInfo message in different modes of operation, roughly increasing in complexity. We use the WGE100 camera10 as an example. This camera has 752x480 resolution, but is commonly used in 640x480 mode, which crops the left-most and right-most 56 columns of the imager. It supports both binning and ROI.
The camera is calibrated only once, in full 752x480 resolution. The same camera parameters (height, width, D, K, R, P) are reused in all cases. They are combined with the driver's current operational parameters (binning_x, binning_y, roi) to derive the geometry of the output images.
#1 Full Resolution
The most basic case - we capture full 752x480 images. The relevant CameraInfo settings are:
height: 480
width: 752
binning_x: 0
binning_y: 0
roi
offset_x: 0
offset_y: 0
height: 0
width: 0
do_rectify: False
For this example we have left the binning and ROI fields at their defaults of 0. Drivers that do not support binning and/or ROI do not need to touch these fields at all. The above message has the same meaning as:
height: 480
width: 752
binning_x: 1
binning_y: 1
roi
offset_x: 0
offset_y: 0
height: 480
width: 752
do_rectify: False
#2 Region of Interest
Let's capture a 200x300 ROI with top left corner (50, 70):
height: 480
width: 752
binning_x: 1
binning_y: 1
roi
offset_x: 50
offset_y: 70
height: 300
width: 200
do_rectify: True
The driver simply needs to fill in the roi field. roi.do_rectify is now set to True, as the best-fitting rectified ROI may overlap poorly with the original raw ROI.
Now we change the camera to 640x480 mode, cropping 56 columns on each side:
height: 480
width: 752
binning_x: 1
binning_y: 1
roi
offset_x: 56
offset_y: 0
height: 480
width: 640
do_rectify: False
The cropping effect of the lower-resolution mode is encoded in CameraInfo as a ROI. roi.do_rectify = False because we wish to pretend that we are in fact running a 640x480 camera at full resolution. The rectified image will also be 640x480.
#4 Cropped Video Mode with ROI
Again capturing a 200x300 ROI with top left corner (50, 70), this time with respect to the 640x480 image:
height: 480
width: 752
binning_x: 1
binning_y: 1
roi
offset_x: 106
offset_y: 70
height: 300
width: 200
do_rectify: True
Notice that the ROI in CameraInfo is actually specified in the full 752x480 resolution we calibrated with. roi.offset_x = 106 = 56 + 50.
#5 Binned, Cropped Video Mode
Staying in 640x480 cropped video mode, we enable 2x2 binning:
height: 480
width: 752
binning_x: 2
binning_y: 2
roi
offset_x: 56
offset_y: 0
height: 480
width: 640
do_rectify: False
The output resolution is reduced to 320x240. Since ROI is specified in unbinned coordinates, the roi fields are unchanged from #3.
#6 Binned, Cropped Video Mode with ROI
Finally, we capture the same ROI as in #4:
height: 480
width: 752
binning_x: 2
binning_y: 2
roi
offset_x: 106
offset_y: 70
height: 300
width: 200
do_rectify: True
Again, the roi fields are unchanged from #4.
Why Include Operational Parameters
In defining CameraInfo, we have included both calibration parameters (fixed until the next calibration) and operational parameters (set by the camera driver, may change freely). The Use Cases section demonstrates how the operational parameters can be used to describe a variety of useful capture modes without recalibrating.
One could ask, however, why include the operational parameters in CameraInfo at all? Binning rescales the focal lengths and principal point. The ROI offset shifts the principal point. A major alternative approach is to modify the projection matrix in the camera driver to describe the geometry of the individual output image. We have three objections to this approach.
First is separation of concerns. In ROS we consider camera drivers to have a very specific function: read pixels off the imager, shove them directly into a sensor_msgs/Image message, and publish. They are not expected to understand the camera model at all, merely regurgitate the calibration parameters provided to them externally. This keeps drivers simple and focused, and avoids requiring external dependencies such as OpenCV.
Second, the operational parameters are useful information in certain vision tasks, particularly ones which actively interact with the camera. The initial motivation for including ROI in CameraInfo was an application which tracked a small object at high speed by updating the ROI of a high-definition camera after each detection11. In this case, we needed to know the ROI of the incoming image to calculate the updated ROI.
Third, CameraInfo as specified permits some convenient optimizations. Without getting deeply into implementation details, rectifying a full resolution image for the first time is a fairly heavyweight operation. It involves generating matrices mapping each rectified pixel to a location in the raw image. These maps can be reused, however, on subsequent images, greatly reducing the expense of rectification. Furthermore, when ROI is used you can cheaply extract and use the same ROI from the full resolution map; this is a nice win when the ROI is frequently changing, as in the tracking application mentioned above. With the alternate approach, changing the ROI likely entails generating a new map specific to that ROI.
Unbinned Coordinates for ROI
The original draft of this REP expressed ROI in binned coordinates with the theory that this is slightly more intuitive to the user. One problem is that binned coordinates are less expressive than the full resolution coordinates; they do not allow bins that start at coordinates that are not multiples of the binning factor. Another advantage of using unbinned coordinates is that the ROI represents the same field of view regardless of the binning settings.
The IIDC (DCAM) 1394 specification12 uses unbinned coordinates and explicitly does allow "off-grid" ROIs in Format_7 (Partial Image Size Format) modes. In contrast, the GenICam Standard Features Naming Convention13 uses binned coordinates for ROI. Thus there is some disagreement among standards, but in the absence of any strong argument for using binned coordinates we opt for the technical advantages of unbinned coordinates.
Rejected Features
Some requested features are not included in this REP, generally because we do not see enough benefit to justify the added complexity.
Different Dimensions for Rectified Image
At least one user has wanted to make the dimensions of the rectified image larger than those of the raw image14. The advantage is that the rectified image can contain all of the pixels from the raw image without under-sampling them. When packing all of the original pixels into a rectified image with the same dimensions, some details can be lost, especially when there is significant radial distortion.
Implementation-wise, this is not particularly difficult. It requires adding fields to CameraInfo for the dimensions of the rectified image at full resolution, analogous to height and width. image_geometry would use these fields when creating the rectification maps. We would add some way to select different dimensions in camera_calibration.
While potentially nice to have, we need more convincing that this feature is actually necessary. camera_calibration's alpha slider 15 already allows the user to choose a trade-off between using all of the original pixels and preserving detail. The cost of adding this feature is some measure of additional complexity, and it is likely to cause confusion. It might break code that assumes the rectified image has the same dimensions as the raw image at full resolution.
Finally, if truly needed, this behavior could be implemented as a node publishing the enlarged and rectified image and a tweaked CameraInfo to a separate namespace. This solution loses the ability to unrectify points back to the original image resolution, but this a minor drawback.
Publish CameraInfo Only When Parameters Change
One FAQ is, "Why send CameraInfo with every Image message? Why not only once?" The main answer is that operational parameters (binning, ROI) may change, perhaps rapidly, from image to image. Even the calibration parameters may be updated regularly in self-calibrating systems.
The natural follow-up question is, "Why not send CameraInfo only when it changes?" The biggest issue is that when the CameraInfo does change, how do you synchronize that change with the Image stream on the client side? Either you go ahead with the most recent parameters, risking garbage interpretation if the new CameraInfo has not arrived yet, or you wait for a CameraInfo that most of the time will not be sent. Worst of all, what if a CameraInfo update gets dropped? In any case, the potential savings are meager, as CameraInfo is much smaller than the typical Image message.
To be fair, this question most recently came up in the context of a camera with a proprietary (and large) distortion model16. Including this model in every CameraInfo message would indeed waste a large amount of bandwidth. Obviously, though, we can't support this proprietary model, and the thread suggested good alternative solutions. As long as CameraInfo remains small relative to an Image, we see no reason to complicate matters in pursuit of tiny bandwidth optimizations.
Mirroring
Some cameras17 support effects such as flipping the image horizontally or vertically, or rotating the entire image 180 degrees. With flags for these settings in CameraInfo, it would be possible to update the calibration parameters with respect to the mirroring. However, this adds complexity in support of a relatively rare feature, and we do not see a compelling use case for changing the mirroring settings after calibrating the camera. The user should look at the raw images, mirror them into the desired orientation, and then consider those settings fixed prior to calibration.
Other Camera Settings
Other settings came up in discussion such as exposure, gain, white balance, color calibration, etc. However these settings are highly camera-dependent, and requiring drivers to convert camera-specific values into some canonical representation would be a significant burden. Furthermore, the main purpose of CameraInfo is to describe the geometry of the captured image, which is not affected by settings such as exposure.
Information such as color calibration could certainly be useful to post-processing nodes, but these settings could just as well be published on some other dedicated topic rather than including them in CameraInfo.
Focus and Zoom
Some cameras support auto-focus, or allow users to set focus/zoom programmatically. These settings do change the optics of the camera, and thus the geometry of the image. Unfortunately, describing the camera parameters as a function of focus is not a simple arithmetic operation as it is with binning or ROI. As far as we are aware, calibrating for focus and zoom is still an open research area with no firmly established solution. It's also unclear how to define focus in a camera-independent way.
For now, camera drivers that expose focus and zoom capabilities will have to be "smarter" than the typical driver and update the camera parameters themselves. Such a driver might store multiple calibrations for different focus settings, or use some more sophisticated model to interpolate the camera parameters to the current focus.
Multiple Distortion Models
Storing multiple distortion models in CameraInfo was suggested, so that code not supporting some new distortion model could fall back to a simpler one such as "plumb_bob". But there are other, simpler solutions to this problem, such as requiring users to upgrade their code (or else calibrate the camera themselves), or shipping multiple calibration files and allowing the user to select one compatible with his system.
Nodes exclusively using image_geometry to interface with CameraInfo (as recommended) should continue to work with no changes. In fact, they will gain support for binning.
Nodes actively using ROI with rectified images, especially if they use the polled camera interface18, will need to be updated. In fact we are not aware of any such nodes in current use. People trying to write them tend to get stymied by the issues with rectifying ROI image patches19. We are not concerned about breaking backwards compatibility with the old rectified ROI, because the old behavior is already broken and therefore little-used.
The biggest pain point is that previously recorded bag files containing CameraInfo will need to be migrated before they work with Diamondback nodes. Still, this is easily accomplished using rosbag fix. The migration rule will fill in the new / modified fields as follows:
distortion_model = "plumb_bob"
D copied as-is
binning_x = 1
binning_y = 1
roi.do_rectify = (roi.width > 0 && roi.width < width) ||
(roi.height > 0 && roi.height < height)
TODO: Define updates to the INI and YAML files used to store calibrations.
Reference Implementation
The new features are not yet implemented in image_geometry. I'd like to reach consensus before investing the coding effort.
CameraInfo and the Image Pipeline, Konolige (http://www.ros.org/wiki/image_pipeline/CameraInfo) ↩︎
Camera Calibration Toolbox, Bouguet (http://www.vision.caltech.edu/bouguetj/calib_doc/htmls/parameters.html) ↩︎
Prosilica rectification is wrong when an ROI is specified (https://code.ros.org/trac/ros-pkg/ticket/4206) ↩︎
OpenCV Camera Calibration (http://opencv.willowgarage.com/documentation/cpp/camera_calibration_and_3d_reconstruction.html) ↩︎
Using Bumblebee Xb3 with image_pipeline, ros-users ML (https://code.ros.org/lurker/message/20100922.120620.d371903e.en.html) ↩︎
polled_camera Package, Mihelich (http://www.ros.org/wiki/polled_camera) ↩︎
image_geometry::PinholeCameraModel Class Reference (http://www.ros.org/doc/api/image_geometry/html/c++/classimage__geometry_1_1PinholeCameraModel.html) ↩︎
wge100_camera Package, Gassend (http://www.ros.org/wiki/wge100_camera) ↩︎
Milestone 2 Explained (http://www.willowgarage.com/blog/2009/07/02/milestone-2-explained) ↩︎
IIDC 1394 Specification v1.31 (http://damien.douxchamps.net/ieee1394/libdc1394/iidc/IIDC_1.31.pdf) ↩︎
GenICam Standard Features Naming Convention v1.4 (http://www.genicam.org/files/u102/GenICam_SFNC_1_4.pdf) ↩︎
Allow image_proc to resize an image (https://code.ros.org/trac/ros-pkg/ticket/3965) ↩︎
How to Calibrate a Monocular Camera, Bowman (http://www.ros.org/wiki/camera_calibration/Tutorials/MonocularCalibration#Calibration_Results) ↩︎
